How to install Team Viewer on a mac?
Good morning,
I wish to access my clients mac computer from my windows using TeamViewer.
She is struggling to download TeamViewer for mac as it is only showing options for iphone/ipad - image below.
Capture.JPGAlso advice on whether she downloads remote control or quick support would be much appreciated.
Thank you in advance for your help.
Ali
  • Esther
    Hi @AliJane89
    Your client can download TeamViewer for Mac from our homepage:
    https://www.teamviewer.com/en/download/mac-os/
    If you would like to connect to your clients iPhone or iPad, s/he needs to download the TeamViewer QuickSupport app. In this article you can learn how to connect to a iOS device. Please keep in mind that remote control is not possible for iOS devices.
    I hope the info helps.
    Best, Esther
  • AliJane89
    AliJane89 Posts: 2
    Hi Esther,
    Thank you that is very helpful.
    Silly question here from me I am sure > do an apple mac count as an ios device? Or will I be able to remotely control from the teamviewer download you suggested?
    If yes, does it work in the same way as windows team viewer to connect?
    Kind regards,
    Ali
  • Esther
    Hi @AliJane89
    No worries! This is not a silly question at all.
    Yes - You can remote control an Apple Mac. It is very similar to remote controlling another Windows Computer (Here is a list of the supported macOS).
    iOS devices are iPhones and iPads for example. Those devices cannot be remote controlled, but a screen sharing is possible.
    All the best, Esther
