I used to be able to download version 12 from Previous Verison button. Is there anywhere I can look for this and re-download version 12?
Hi @usalabs
Thanks for your post and your help!
We recommend to only download TeamViewer directly from our the TeamViewer website. This link guides you always to the right version and source:
Where can I download older TeamViewer versions?
Thanks a lot, Esther
thanks
Hi @Sanjayb381
Thanks for your reply.
I recommend updating both computers to TeamViewer 14 to have the best experience. Please have a look at this announcement to learn more Updating to the latest and greatest version of TeamViewer.
This update might solve any issues you are experiencing.
Thanks and best,
Esther
Hey Esther,
I am using TV 12 and my partner uses the same version. But I still can not connect to my partner pc. When I try to connect partner PC, an error message comes "Reason unknown". Since this is my trusted pc and I have added my partner's id/password in my teamviewer. Can you please guide me how i can connect?
Sanjay
You can use the following link to download version 12.
[removed by moderator]
Sorry for any delays, I have just registered and having a huge problem with TeamViewer 13, I found a whole bunch of older versions for you to pick from at:-
[linked removed - please see the below post for the link to download older versions]
