ID and Passwords
Glenn_Afimilk
Glenn_Afimilk Posts: 2 ✭✭
Is it possible to get a list of all the PC's teamviewer ID and passwords?
  • Esther
    Hi @Glenn_Afimilk
    Thanks for your post.
    There is no general list of all TeamViewer IDs and passwords. But to make it easy for your to quickly connect to all your devices we recommend to work with the Computers & Contacts list in which you can save all devices with an alias and the password.
    I hope the info helps you.
    Best, Esther
  • Glenn_Afimilk
    What happens when you lose your list of unattended access passwords or you want to just back them up?
  • Esther
    Hi @Glenn_Afimilk
    Since the list is saved online, you cannot really loose it.
    You could of course share the different groups in your list list with a colleague to make sure that a second account has access to the remote devices.
    Best, Esther
  • longbeachRita
    longbeachRita Posts: 5 ✭✭
    I don't see the option to save passwords. Has this changed?
