I just got the Note 9 and accepted Knox activation and I can't get TeamViewer to connect - perpetual "connecting to..." on my computer screen, while the phone acts like it's connected. I installed both QuickSupport and TeamViewer Host.
Hi everyone,
Thank you for your patience.
We have a special test version of the QuickSupport and Host app for Samsung devices which does not link to Knox anymore, which we hope should resolve issues related to Knox.
QuickSupport download: https://teamviewer.box.com/s/hdpfufxxdk2fi88gwa3wtzr4cvil0zmcHost downlaod: https://teamviewer.box.com/s/eg85l2lng2ny7ilebcafbqobyz9gk0kd
These versions should automatically prompt you to download the Samsung addon:https://play.google.com/store/apps/details?id=com.teamviewer.quicksupport.addon.samsung
Can users please try this with the Samsung Note 9's and report the result here?
William
Hi William - where are the links for these files. Thanks Ian
@William_L can you please reupload these versions? I have note 9 with the latest updates, but I cannot get teamviewer host to login at all and have a log showing as much.
I hope you can give us fresh links so we can download these apks again. Thanks
Still Doesnt works on Samsung Note 9
files are no longer availabel :-(
This problem is also on Samsung XCover 3 running latest Android 8.1 update.Installed the TeamviewerQS.apk file linked to, and installed addon. It then works as expected.
Finally got it working.
Thanks a lot!
I have installed both the QuickSupport app as well as the samsung add-on.
So far it seems to work smoothly....
I tried this and it did not work for me, tried uninstalling it completely and restarting the phone and it did not work. .
Great! Works for me. Samsung Note 9 on latest updates. (European version).
Same problem with my note 9. I called Samsung support and got no help at all!
Yep, same problem on my note 9 as well. Hoping for a fix soon
Have you heard?! On October 21, we’re hosting TeamViewer Rise—and we want to see you there! The digital event dedicated to IT experts. Join us to hear industry leaders as they share demos, roadmaps, and real-world strategies for delivering better IT. Take part in our first annual event for Proven, ready-to-deploy…
