teamviewer
can't set up on mac
  • DomLan
    DomLan Posts: 490 ⭐Star⭐
    sorry, but with no more explanation I can't be more accurate.
    I did not understand if the problem is to configure the product or installing the same.
    In the first case it may be useful to view the information contained in the log file.
    In the latter case you should try to provide a few more details.
    Domenico Langone
    MCSD: App Builder
