19091939596343
  • argy
    argy Posts: 1
    I have same problem, today teamviewer let me connect only for 5 minutes but is not commercial use of application, why? can do for resolve taht issue?
  • https://www.teamviewer.com/en/support/commercial-use-suspected/
    This link should give the form, but it gives 404 error. I submitted the form a while ago and did not get any response. Maybe the form URL is changed? If so please publish the link.
  • dano
    dano Posts: 2
    Help, help, help.
    I wonder if this is what's causing the commercial use issue with one of my laptops. @JoshP I have gone through the reset request form and not been reset, nor provided the decloration to fill out. Is TV having a problem with the resets? It's only on one of my eight devices, but I can't reach the other seven (in the same house) from the one being blocked.
  • nevillet
    nevillet Posts: 1
    I had a message that it was suspected I was using Teamviewer commercially and responded that it was only private use. On 23 Feb I received an email that said:
    Thank you for getting in touch with us. We are happy to inform you that your TeamViewer ID has been reset to “free”. After reviewing your request, we decided that your use case can be qualified as “personal”.
    I did not try until today to use it, but I receive the same commercial message. If I click OK I get a password window to log into the remote computer. Enter the password, and I see the remote computer but it logs me out in about 10 seconds. I am then blocked for 10 or 15 minutes. I don't seem to be able to contact Teamviewer direct so what do I do?
  • Natascha
    Natascha Posts: 1,527 Senior Moderator
    Hallo Martin,
    vielen Dank für deine Rückmeldung.
    Wir sind uns der Verwirrtheit unserer Nutzer bewusst, die davon überzeugt sind, dass sie TeamViewer nicht geschäftlich nutzen. Wir gehen jedem Fall nach und werden auch dein Gerät (TeamViewer ID) freischalten, wenn dies irrtümlich eingeschränkt wurde.
    Mach bitte in deiner Anfrage konkrete Angaben, damit wir dein Nutzungsverhalten verstehen. Kontaktiere uns bitte nicht mehrmals mit derselben TeamViewer ID – sobald du deine Anfrage abgeschickt hast, wird diese bearbeitet. Bitte beachte, dass wir die Anträge in der Reihenfolge ihres Eingangs bearbeiten, die ältesten zuerst. Wenn du uns erneut eine E-Mail sendest, beginnt die Bearbeitungsdauer von Neuem. Bitte denke daran, das Formular in Englisch auszufüllen.
    Du kannst sicher sein, dass wir alle an uns gestellten Anfragen bearbeiten. Aufgrund der großen Anzahl an Anfragen kann die Beantwortung etwas Zeit in Anspruch nehmen.
    Bitte prüfe, ob sich unsere E-Mail in deinem Spam-/Junkordner befindet, wenn du nicht innerhalb einer Woche von uns gehört hast.
    Herzlichen Dank für deine Geduld und einen schönen Donnerstag.
    Viele Grüße
    Natascha
  • Martin02
    Martin02 Posts: 12
    @Natascha warum soll ich nun wieder dieses Formular ausfüllen??? Letztens sagte man ich soll mich im forum melden!!
  • Error 404
  • pjgfi
    pjgfi Posts: 4 ✭✭
    Maybe it's a good sign that there's currently something wrong with the detection and they're updating the page...
    EDIT : no, page is back...
  • thomy
    thomy Posts: 1
    Ich habe das gleiche Problem. Wenn ich den Link zum Formular zur Beschreibung der Nutzung anklicke, bekomme ich immer eine Fehlermeldung. Offensichtlich hat Teamviewer etwas losgetreten, was sie nun nichtbewältigen können. Herzlichen Glückwunsch! Sehr unprofessionell!
  • Natascha
    Hallo @thomy,
    vielen Dank für deinen Post und herzlich willkommen in der deutschsprachigen Community.
    Kannst du bitte noch einmal versuchen, den Link auszuführen? Er sollte jetzt wieder funktionieren.
    Du kannst sicher sein, dass wir alle an uns gestellten Anfragen bearbeiten. Aufgrund der großen Anzahl an Anfragen kann die Beantwortung allerdings etwas Zeit in Anspruch nehmen.
    Herzlichen Dank für dein Verständnis und einen schönen Donnerstag.
    Viele Grüße
    Natascha
  • Natascha
    Hi there,
    Thank you for your posts.
    Can you please try again to report your case? The page should now work again.
    Thank you and sorry for any inconvenience caused.
    Natascha.
  • JoshP
    JoshP Posts: 826 Senior Moderator
    Hello @dano
    There is no issue with forms already submitted. This was an issue with the website itself, and accessing the form in order to submit new requests. The issue has already been resolved, and the form is accessible again.
    Regarding any form already submitted, we aim to resolve all requests withing 7 days, but it may take longer due to the number of requests. We thank you for your patience.
    Josh P.
    Senior Community Moderator
  • Hello,
    I use teamviewer for purely personal purposes, to connect to family computers.
    I am at the end of the trial version period (already extended by 7 days).
    How to get back to the free version? The commercial version was "imposed" by an update. I could not get the answer over the phone.
    N.B I already made the request a few days ago but did not get an answer.
  • dano
    dano Posts: 2
    Thanks @JoshP . I was hoping as it's been a month.
  • winslow3965
    winslow3965 Posts: 4 ✭✭
    Dear Sirs, I just disturb you about a problem I have with my teamviewer license; I'm a home user and I can confirm that no professional or commercial use of Teamviewer has ever been made, but some days ago a messsage appears: "commercial use suspected..." and my teamviewer sessions last just 5 minutes from that momento on....
    Again I confirm that only personal use of the sw has been made (management and maintenance of friends and relatives pcs, in addition to mine when I'm out of home); so please, if it's possible, re-.activate my teamviewer license asap.
    Thank you in advance for your kind cooperation and best regards
    Luca Baruffaldi
  • Don't use TV for personal use. I have in the past, and it was a good product, mostly stable. But even though using it to connect to a remote computer a few times a month, TV kicked me out and wanted to sell a licence. You should try **Third Party Product** instead. Not an easy setup but once you get there, it works.
  • Ich habe seit einiger Zeit, vielleicht ein paar Wochen, Probleme mit Teamviewer.
    Ich nutze das Programm um meinen Verwandten zu helfen und werde fast immer nach ein paar Minuten rausgeschmissen mit der Meldung dass der Nutzer ein paar Minuten gesperrt wird.
  • A few months ago one of my pc's was blocked for Commercial Use. I uninstalled and forgot about Teamviewer for a while. Today I reinstalled Teamviewer on the PC again. It's working now but I'm getting Suspected Commercial Use Pop ups. I really don't want it blocked again. Please, what do I do? I only use this pc as the household media server.
  • PraO
    PraO Posts: 2
    Bei mir ist das genau so. Man kann praktisch nicht mehr damit arbeiten.
    Auf diversen Seiten habe ich als ältere Begründung gelesen, dass das wenn man es übermäßig benützt so sein soll, aber bei mir kommt es auch, wenn ich vorher 1-2 Wochen mit niemand verbundem war. Gefühlt ist das so seit dem Upgrade auf Version 14.
  • Natascha
    Hallo @Tommyfare @PraO
    vielen Dank für eure Posts und herzlich willkommen in der deutschsprachigen Community.
    Könnt ihr bitte nachschauen, welche Versionen auf beiden Seiten installiert sind? Stellt bitte sicher, dass ihr auf beiden Seiten die aktuellste Version verwendet.
    Gerne könnt ihr auch einen Screenshot der Meldung hochladen. Achtet dabei bitte darauf, dass keine TeamViewer IDs, Passwörter oder Emailadressen ersichtlich sind.
    Solltet ihr Fragen dazu haben, stehen wir euch gerne zur Verfügung.
    Ich wünsche euch einen guten Start in die neue Woche.
    Viele Grüße
    Natascha
  • Hallo Natascha.
    Es ist auf beiden Seiten die aktuellste Version installiert.
  • I had a problem while I was transmitting my pc to a friend of mine via teamviewer and in the meantime I received the message from Ban because I used the account for commercial purposes when it is not true
  • PraO
    PraO Posts: 2
    Hallo Natascha,
    mein Problem ließ sich tatsächlich beheben, wenn beide Seiten mit der aktuellen Version 14 arbeiten. Bisher habe ich das nicht so genau genommen, da es nie Probleme damit gab.
    Damit es verläßlich funktioniert, musste ich meine Installation komplett entfernen und durch eine frisch heruntergeladene Neuinstallation ersetzen. Denn ich bekam beim Start eine Meldung in Englisch, dass ich auf die neueste Version wechseln muss.  Bin ich aber auf Update gegangen, hat er mir auf Deutsch bestätigt, mit der aktuellsten Version zu arbeiten. Dieses Verhalten ist seit der sauberen Neuinstallation weg.
    Bei meinem Freund (Version 10) und meinem Vater (Version ca. 12) habe ich jeweils die aktuelle Quick-Support Version heruntergeladen und seitdem hat die Verbindung länger als 5min gehalten.
    Vielen Dank für die Unterstützung,
    Oliver
  • fripzap
    fripzap Posts: 1
    hello, teamviewer detects a commercial use while it's wrong how to do? thank you
  • Did it fix itself or how did it get fixed?
  • Natascha
    Hallo @Tommyfare
    könntest du, wie @PraO, bitte einmal versuchen, TeamViewer auf beiden Seiten komplett mit allen Einstellungen zu deinstallieren?
    Installiere ihn anschließend erneut und teste es bitte noch einmal.
    Ich hoffe sehr, dass das hilf und freue mich auf deine Rückmeldung dazu.
    Viele Grüße
    Natascha
  • Good day;
    Although after claiming for the commercial use of the product, you have answered me
    "After reviewing your application, we decided that your use case can be described as" personal "
    I still have the same problems of not being able to connect with my equipment.
    Do I have to do some other procedure for TeamViewer to return to its private use situation?
    Thanks and best regards
  • Did it ever get reset properly? I'm still waiting.
  • Today nothing change. still limited 1min max
  • And there's no technical support or contact for free users to follow up. So I guess we just have the one minute free version that just keeps telling us commercial use detected even though we've also been told it isn't.
