Weird overlay problem since Windows update 1803 (Build 17763.379)
kobii
kobii Posts: 11 ✭✭
Every time if i lock my system with "Windows-Key + L" and unlock it I have this weird overlay.
This overlay locks the input completely. I can't move it and I have to restart the TeamViewer.
Can you fix it?
Best regards
    Hello @kobii,
    This is indeed an unexpected behavior.
    I would recommend you to uninstall completely TeamViewer (by clearing also the registry) and to reinstall our latest build on our website.
    I hope this could fix the issue.
    We wish you a good weekend ahead.
  • kobii
    kobii Posts: 11 ✭✭
    For a few days the solution worked, but now I have the same problem again.
    TV has been uninstalled
    Registry cleaned up
    Last version installed
    A colleague in the company has the same PC (identical Windows version) but does not have this problem.
    Hello @kobii,
    This means that it is not a general problem and it has to be something on your device.
    Maybe there is something about your graphics card.
    Could you please check if the drivers of your graphic-cards are up-to-date? I recommend you to visit this How-To: How to update Graphics Drivers in Windows 10
    Let us know if this has fixed your issue.
    We wish you a good rest of the day.
  • kobii
    kobii Posts: 11 ✭✭
    Hello @JeanK
    I will try it today.
    I will give you feedback tomorrow.
    Kobi
  • kobii
    kobii Posts: 11 ✭✭
    It doesn't work. I have updated all my driver, my windows and cleaned registry and some stuff.
    I have still this weird overlay. Mostly I get this overlay after terminating a TV session.
