From a Windows 10 PC any remote host only shows a black screen
I am on a Windows 10 PC. When I connect to any remote host (Mac, Windows Server 2012, etc.) I only see a black screen.
I have updated my TV software, all drivers and Windows updates. Also did the same for the remote hosts.
If anyone has any ideas, I'd love to hear them.
  • erniemjt
    erniemjt Posts: 3
    I'm running version 14.2.2558 with a premium license.
    JeanK Posts: 4,169 Moderator
    Hello @erniemjt,
    Indeed, this problem has been reported by some users in the past. Therefore, we have created two articles about this topic. Please have a look at them, you might find the solution to your issue:
    French Community Moderator
  • erniemjt
    erniemjt Posts: 3
    Thank you for the suggestions @JeanK! Unfortunately, neither link was helpful in the situation.
    I can use my Macbook to connect to Server1 with no problem. When I use my Windows 10 laptop, black screen. From my Windows 10 desktop, it works fine. It is only on my Windows laptop which is what I use 99% of the time for my connections.
