Appreciated if you could guide me how to solve this issue. The application unable to connect due to the above errors.
Popped up again this morning... Well...with popped up, i really mean lots of pop ups :-D
Changing the proxy settings in Configure Network fixed it again.
I wonder for how long.
Fixed it for me too. It was set to 'browser proxy" and I put it on "no proxy". Issue solved, you are the best!
I got it fixed by changing the proxy settings to using "No Proxy" instead of the recommended settings.
(Preferences => General => Proxy Settings.
Hope it helps!
Nico
same here!
Same here. Installed latest version, deleted preferences. no matter what I try, I will get those popups. No idea how this happened. Seems that a lot of people have this issue. The ini-error is weird since the Mac doesn't use ini-files.
I have the same issue. v 14.3.4730 (Jun 5th)
I tried reinstalling, doesn't help
On the Sign In ab in the app, i can't press Sign-In, it's greyed out
Tx,
Hi @azrull
Can you kindly check the version of TeamViewer you are using please.
If possible, kindly download and install TeamViewer for remote connection please.
For further assistance, feel free to contact TeamViewer.
