I don't find logfiles of my connections on MacOs
SaadSrs
SaadSrs Posts: 2
Hi, there
I am having a problem that i don't find any log files or teamviewer folder in this directory
TeamViewer Full Version, Host, and QuickSupport:
Macintosh HD > Users > [username] > Library > Logs > TeamViewer
and I am sure that the log settings are "on" in the teamviewer
Can you please guide regarding this because I really need to know the storing technique for the logfiles on MacOs???
    Hello @SaadSrs,
    You will find all the information you need regarding the Logs storage in our Knowledge Base article here: How to find your log files on Windows and Mac and Linux
  • SaadSrs
    SaadSrs Posts: 2
    Thank you for your replay @JeanK
    but I have seen this article, and I follow the instructions but as I said i don't find any log files in there.
    and I am sure from the settings on the teamviewer for the log saving is turned on
    My regards, thanks
