Answer to your first question is yes I did.
Second question two months. And the last is patience. Use your time on third party software.1 -
#metoo: I was also restored to free, after submitting the form for all the TV IDs... after a while (I didn't count and didn't kept the email) I receive an email that's ok... but it didn't say for which ID it was ok. So I kept using version 9. After another while I received another email which said for this ID (again they didn't say which one) we cannot determine the personal use, sign the form that you're using it for personal use and send it back to us. Again no answer at all, and after a while version 9 was obsoleted, I could no longer use it (they were backporting warnings in this version too), I installed version 14 and voila, I was free again. For how long? No one knows.
i get a message before i connect that i am allow 5 minutes access remote computer
once i am in, within 20 seconds. I do not use team viewer for commercial purposes. Thanks1 -
I have, it took around 25-40 days, but no matter what, it keeps reoccuring.
Because something keeps re-triggering it. I even remote from my phone to my home PC.
If I needed to access some personal data on the go, or run updates to my PC games so they're in a ready, playable state when I'm home - but TeamViewer warns that if I'm connected to a public WiFi: Starbucks, McDonalds, etc
That will trigger it again. Because I'm connecting in from a Commercial connection. Which I don't do, as I have a large enough mobile data plan to not rely on unsafe public WiFis.
So then I was warned based on how the Mobile ISP relays, it may be detected as commercial as well..I've been detected at least 4 times by now. Their detection system is WAY too sensitive, and is leading to more false detections than anything.
Yesterday my Team Viewer 14.4 started timing out after a few minutes. I have not had a problem with it before this. Also, I have not changed anything on my laptop or any of the settings with Team Viewer. I uninstalled the software and reinstalled the software, still having the same problem today. I did a google search for this issue and no help there. Any assistance would be appreciated because currently the software is unusable and I'll have to move to ***Third Party Product***.
One more story that confirms my belief this is done on purpose in order to either convert free users to pay, or dismiss them.2
I'm guessing TV is cleaning house and making it orderly for their potential IPO. Time to boot the freeloaders and close support for them. No tickets allowed. No notification that a support form was submitted appealing their claim of comercial use. Playing an automated message and hanging up when you call into support for the free client. Nothing.
After getting my warning yesterday, setup [third party product]
Both work great. I recommend CRD for anything using the same email address in your browser and I recommend AD for family/friends where you don't want them logging into your email address in the browser.
I still have teamviewer installed becuase it does work between residential connections. So far, it only triggers the warning if you're using a commerical connection: internet at restaurants, work, school, etc.
But this way, if teamviewer doesn't work, I have two other solutions already setup and waiting for me to use them.
They should seriously just limit the amount of PCs or time used or something, instead of trying to judge everything by whether its a "commerical" connection or not. Lots of "commerical" connections are used for personal use.0 -
i am only use teamveawer for fam and frind but now the block me dont no wy can you help me
"https://finance.yahoo.com/news/permira-backed-teamviewer-ceo-backs-**Please do not post TeamViewer I..."
Dead link unless they truncated it.1 -
Yeah their auto-filter nipped it because it thought I posted a TeamViewer ID.
Try this instead: Permira-Backed TeamViewer CEO Favors Possible German Tech IPO
2 -
This has happened in the past, but TV was prompt about getting it resolved. This time, I've not even recieved *any* notification that they've even recieved the form to have the "commercial" flag removed from my system/account.
Is there anything that can be done to clear the false accusation of commercial use or, alternatively, any means of contacting TV (with regards to this issue) to see if they've even gotten the form into a queue of some kind?
As of right now, I'm not even getting the 5 minute connection the application states I'll get. It cuts the connection in a minute or two every time I've tried, making it wholly unusable. And, yes, I've timed it.3 -
They need to come clean.
2 -
doing the same thing to me. I use it to connect to my upstairs computer and downstairs. also use it at work to connect to home computer to shop. Now it's flagging me non stop. Any fix to this??
4 -
I am having the same issue as well. Started this morning for me. I use it to connect to my home PC from work so I can access my personal email and such.
5 -
Just started for me this morning. Been connecting from my work computer to my personal computer at home to check my email for years.
7 -
Same here! I use to connect to the same room desktop from my tablet and now it says commercial use detected and states it gives me only 5 minutes but disconnects in less than 2!
5 -
Update. I uninstalled version 14 and installed version 13 and had the same problem. that I had with version 14, it times out with 2 minutes.
A few days. As you can see, the two computers are very, very, very apart
Very distant computers...
My account is literally my PCs and they marked me as a business trial and I have no way to contact them... this is crazy...4
Same, I don’t know how to get in contact as their phone hangs up and tells you to submit a ticket. Guess imma have to call sales to try to reach someone2
another update: I can not start a TV session, however, I can log on to a TV another computer starts and it works fine. So the problem is just with this computer starting a TV Session.
Go to teamviewer.com/unblock to put in a ticket.3
ive put 2 in.. now it says i am limited to 5 mins.. i get 28 seconds and then it times me out for 11 mins.. What the serious **bleep** is wrong with TV
4 -
this does not work i have filled in a lot of forms over the course of 6 monts and the only 2 responses i got where basicly **bleep** you and pay
3 -
I am having the same issue today, but I think might have started yesterday. I am the tech support person for my friends and family, so I have 14 computers in my connections list. I am NOT using TeamViewer for commercial purposes.
3 -
I had the block removed last October, about 1 month after submitting one form for my main computer out of 4 using TV.
BUT... ever since, each time I start TV, it pops up a nag screen basically telling me it doesn't trust that I'm only using it for personal use, and why don't I pony up. Then it allows me to use it without any restriction. It's not nice using software that tells me it suspects me of cheating every time I use it.
And no, I don't use it commercially, just to save me running from room to room, and to give me access to home computers when I'm on vacation.
2 -
If you want to mention an alternative product (which they wouldn't be afraid of if they felt their product was truly competitive), just obscure it a little, like "Third party product".
Also, you people are doing it wrong when you threaten to stop using the product because of the bogus Commercial Usage detection. Don't you get it? They are trying to get rid of their free tier users. They _want_ you to quit using the product.
Instead, threaten to post in every possible location on the web about how bad their product is, how poor their business practices are, how they are liars and cheaters and scumbags, rate their product down on all app stores, and competitors up, post to twitter, facebook, EVERYWHERE until the world knows the truth about Teamviewer.
Maybe that threat (promise) will get their attention. It's not good business practice to bait and switch and lie to humble masses, they should know this by now. If they keep going like this, they will go out of business.
5 -
+++ for AD mentioned above. Faster connect than TV. Just swapped to it today. No ragrets.
