1142143145147148252
  • Kym
    Kym Posts: 1
    Oct 10, 2019
    I have only used the FREE VERSION to work on my parents computers as they don't know tech. Today I tried to help my Dad with his Facebook but could not get in.  Tells me that ONE OF US has a Commerical Version and we are limited and must upgrade or use the Free Version.
    We ARE using the FREE VERSION.....   everytime I try to get in it bumps me off.   I installed a VPN on our computers and noticed that the VPN had to be turned off for me even to attempt to connect.     My Uncle tried to connect to my Dad's computer and was able to get in with no problem.... However MY computer is being LOCKED OUT...
    Help I am my only TECH for my parents ..... I finally taught them how to use the computers I bought them but now I can't get in and help them remotely and I LOVE team viewer...
    Some please UNLOCK ME....   LadyKym....
  • GuruMBP
    GuruMBP Posts: 15
    Hi, try login on, click on first Icon and login with your email and password. Maybe you are logoff.
    Apologize my bad english.
  • I got a false commercial use detection.  When I went to fill out the form to appeal the flag - https://www.teamviewer.com/en/support/commercial-use-suspected/ - I am unable to fill the required Affected TeamViewer ID field.  When I click on the field, it fills with dashes and does not permit me to type anything in it; when I click back out of the field, it empties again.
    I have duplicated this behavior on multiple computers and multiple browsers.
  • rfh1987
    rfh1987 Posts: 3 ✭✭
    This just happened to me.  I've been using TeamViewer to access my home computer whenever I need to for over a decade.  Now, they've blocked me.  I called them, to figure out why, and they told me that "Personal Use" means you can only connect from a home network to a home network.  Since I was remoting into my home computer from work (even though it was only for personal use), that is considered a violation of the Personal Use license.
    She told me to find a different solution.  This is so annoying.  Especially since I've been such a long-time user, and I'm only using it for personal use.  They need to change how they decide personal use.  I can't justify spending $50 a month to be able to remote into my computer a couple times a month.  This is making me so mad.
  • @rfh1987
    I travel a lot and need to access my home computer on extremely rare occasions as well, but 99% of the time, if it is for personal use, I can do it on my smartphone.  There are very few things I can not accomplish on my smartphone that I need to access my home computer for.  Since you said that you only need to use TV to access your home computer a couple of times a month, maybe I can help you find a better way to do this on your smartphone, then having to access your home computer.  Tell me what you need to do and I will see if I can help you.
  • rfh1987
    rfh1987 Posts: 3 ✭✭
    @Johnhoward28 I do occasionally use the phone, but the computer is much easier to use, if there's another option.  I'm looking into setting up home VPN with my router or **third party product**, both of which will let me use the computer with much more ease than depending on the phone.
  • @rfh1987
    Okay.  Well, if you are not using TV to access work-related content on your home PC from work, then I would call back in and explain to them what type of non-work-related content you are accessing on your home PC from work.  First level CS agents are generally just people that are trained to read a screen and push buttons, they generally have very little true technical knowledge about how things actually work.  I would try again with a different agent or ask to talk to a 2nd level support agent.
  • Steve-in-FL
    Steve-in-FL Posts: 27 ✭✭
    I went to the link you provided and it allows me to fill in the field (although it does initially fill with underscores). However, if I am using the number pad on the right of my keyboard and IF I DO NOT HAVE NUMLOC TURNED ON it will not enter any numbers. So check if you have NUMLOC turned on. Another test is to use the numbers above the QUERTY row on the keyboard. They are independent from the keypad and the NUMLOC setting.
    If it's not that, I don't know what else to suggest.
  • When I was setting up my new PC I mistakenly selected the "both" option when prompted about commericial usage. I have requested my ID be reset to free twice and both times I have received an email confirming it has been set to free usage. The first time after it was reset, the trial was still showing as expired. After searching this community, some suggested submitting the form again and making sure the ID is correct. I did so and it is still showing as trial expired.
  • pcvang
    pcvang Posts: 1
    I have the same issue. I am using teamview between my desktop and cellphone, however, it says that I need a commercial version. But I use teamview as private or personal use between desktop and cellphone. How do you solve this issue? Thanks
  • DanLester
    DanLester Posts: 31 ✭✭
    Let me put this all in one place. If your TeamViewer account was blocked because they think you're doing commercial activity, and you're not, you can plead innocence with this form here.
    http://cdn01.teamviewer.com/teamviewer/pdf/TeamViewerDeclarationOfPrivateUse.pdf
    You send it here.
    [email protected]
    DO NOT WAIT FOR A RESPONSE. They won't answer. After a while (days, maybe a week or two) your TV capabilities will be magically restored. I did this last month, and it worked. But if I were you, I'd look into any of the several free apps that do TV capabilities, but without the commercial access requirement.
  • Here is the Link to the FORM you must Submit...
    It took me a long time to find it,  I hope it might help someone else.
    Takes a few days to a week,
    I just found the reply was in my Junk folder.
    So there is a reply.
    I seem to have to request a reset every 2 months.
    and as i only use it about once a week for 1 or 2 minutes at a time
    Their AI detection algorithm must be very sensitive and flags the Use as suspicious.
    Tonight I again got the commercial use Popup, and that it would shut down in 5 minutes.
    5 minutes would have been long enough for me to check my Remote PC.
    but It shut down in less than 30 seconds.
  • xbee2
    xbee2 Posts: 17
    The commerical appeal form is useless. I applied in June, and it's now October. No reply.
    My client was frustrated with Team Viewer, and I expressed how poor my experience with them had been too; and guess what? They cancelled TeamViewer! Word spreads.
    TeamViewer isn't priced for personal/home usage, no where near it.
  • Technut
    Technut Posts: 14
    @Johnhoward28 You're fully aware of how badly TeamViewer is treating legitimate free users and yet somehow you never seem to get tired of making excuses for TeamViewer.
    How many years did you say we need to wait for them to change? Oh ok then... I guess we should just quietly wait and compliment them on their product (honey) instead of pointing out their terrible behavior (vinegar). I'm sure *that* will accomplish a lot.
    Just how much are they paying you to do their Public Relations?  Was this excuse PR campaign "They're really good people who happen to be incompetent with free users" your own idea that you pitched to them?  ;) lol
    Kse Dyna --
  • @xbee2
    That is a good testimonial.  TV needs to hear more of these.  One bad decision can mean the ruin of a company in today's world, where everyone has a voice and can make it heard.  Bad PR is really bad for business.  TV is obviously afraid of competition because they aggressively delete any reference to alternates to TV, so they are LISTENING.  The more they hear about people actively encouraging people to go elsewhere, this will hopefully encourage them to take a greater interest in improving their system to **bleep** out cheaters and not punishing legitimate personal users.
    This, of course, is assuming that TV still even wants to offer free service to personal users.  A lot of services like TV, started out offering free service to build their brand on the backs of free users, and then, once they had a firm standing in the industry, they switched to a Pro only model. I used **Third Party Product** before I switched to TV.  They went Pro Only after they had enough exposure and are still around today, and doing quite well.
    So, it is a gamble what TV will do if they get enough bad press from free users.  They may try to improve their cheater detection system, or they may decide they do not need free user promotion anymore and go Pro only like **Third Party Product** did.
  • @Technut
    Nowhere have I promoted anything.  What I have done is tried to add balance and reason to the conversation.  I don't mean to sound mean, but I have no love for whiny little entitled millennials who think they should get everything for free in life and show no appreciation for the blessings they have.
    I am a realist.  Here is a little reality 101 for you.
    1. Teamviewer is a private For-Profit corporation that is in business to make money, NOT give you free stuff.
    2. If you have received FREE service from TV you should be GRATEFUL for what you have received
    3. Since you are not PAYING for the service you have NO RIGHT to DEMAND ANYTHING from TV.
    4. TV has the RIGHT to deny service to you for any reason they want to.  You have no RIGHTS. Zero, Zip Zilch, NADA!
    5. If you want the RIGHT to complain about the service you are getting, then PONY up and pay for the Service.
    6. Whining and complaining about how bad FREE service is, is illogical, unreasonable, ignorant, infantile, and immature.
    Do you think that any PAID representative of TV would write the above words?  Not on your life!  You had better read them fast before they are deleted by the MOD for not being "Friendly".  But even if the mod deletes what I said, ever word is 100% the absolute truth.  Welcome to the REAL world.
  • @Johnhoward28 wrote:
    @Technut
    I'm afraid that what is being said here is indisputably correct
  • rfh1987
    rfh1987 Posts: 3 ✭✭
    That probably is all true, but there's a flip side...none of that is going to keep people using TeamViewer.  It's not worth the effort for people, when there are other solutions.  Maybe if TeamViewer was priced for personal use, but their only personal use price is free, and they lock it down beyond reason.  $50 a month is WAY TOO HIGH for personal use.  For that price, you can get all of below:
    • Office 365 for your whole family
    • Xbox Live Gold
    • Xbox Game Pass for Xbox
    • Xbox Game Pass for PC
    • Spotify Premium
    • Hulu
    • Netflix
    • Amazon Prime
    And if they switch to a paid model for personal use, why would anyone do it when there are free options?
    • Xbox Live Gold
    • Spotify Premium
    • Hulu
    • Netflix
    • Amazon Prime
    That is mostly true – except that teamviewer is extremely good and I'd be very pleased to pay a reasonable annual subscription that could fit in with my retirement pension.
    I think everybody is pretty surprised that they don't do a pricing plan for individual private users.
    @Technut
    Yes. It is indeed correct.
    I do think it's a little condesending to balme all of these complaints to "little entitled mellinials."
    Most people are not complaining about the action or policy itself. People are complaining that even thougha process to overturn the decision is in place, TV basically doesn't respond to most requests and never fixes the issue.
    As with most people, the original poster decided to put the blame back on the user rather than the company that fails to respond. The real problem I have with this is the lack of any response from TV. If TV wants to say, "get over it dudes, we aren't doing anything about it", thank ok we move on. But they haven't.
    As the original poster suggested, I moved on to other avenues. This is something the rest of you should do as well.
  • gbtota
    gbtota Posts: 2
    TeamViwer has a stupid and inaccurate mechanisms for detection of commercial use. They basically look up your external IP to see if its in "residential" space. If you use VPN or have a business connection of any kind it will automatically think you use it for business. Its pretty idiotic way of detecting; and only creates user friction. [removed per Community Guidelines]
    This product will die since its not user friendly; they are hurting themselves by creating user problems or whats already a buggy product.
  • I am being accused of commercial use and it is not so please hrlp me
  • IgorZ
    IgorZ Posts: 5
    I wrote about the Teamviewer Host v14. He does not know how to find an Internet connection when it is for all other programs. And this is only for Teamviewer Host v14.bad TV.png
  • accidently installed on commercial ...how do I revert to personal use
  • Nizar
    Nizar Posts: 1
    I got flagged for using my account for commectial use. I need some clarification before i sign the Form they sent me so i do not get myself blocked. Forever.
    This is what i have in my TeamViewer account:
    Win10-A (My home machine)
    Win10-B (Brothers machine)
    Win10-C (Father)
    Win10-D (Plex/Media)
    Win10-E (Virtual machines host)
    Win2k12r2-F (Virtual machine)
    Win10-G (another brother work laptop)
    From what i understand is i have to remove the Win2k12r2 machine which is not a problem, its just a test VM i play with from time to time.
    Other machines should be fine too for the free version.
    My question is regarding Win10-G, it runs on one of my brother's work laptops in his office, he has a small company with 4 offices.
    The laptop is part of a domain.
    I do not work there and i am not providing paid support or anything for him, i just log in to his laptop whenever he has an issue or wants to show me something.
    So do I have to remove this Win10-G device?
    Also, if i remove the Win2k12r2 and Win10-G device, should i sign the form comfortably and be able to use the free license?
    Thank you in advance!
  • Steve-in-FL
    Win10-C (Father)
    From all that I have been reading, and without reviewing all of the official documents, I would say that both of those machines have to be removed. It has been quoted by others that any machine used in a commercial environment (an office) is considered commercial, no matter its function. And servers are considered commercial.
    I don't agree that these rules are well thought out - they eliminate "friends and family" just because of where a machine happens to sit and they eliminate hobby computing (playing with servers or virtual machines) -  but they are the rules and we have to follow them to use a free product.
    I would sign the form and get on with life. If we are all wrong in our interpretations about the rules, you only risk being blocked. It's not the end of the world. Just my opinion.
  • My laptop was flagged by TeamViewer as possibly being used by commercial use.
    1.) I submitted the proper form explaining what I use TeamViewer for.
    2.) TeamViewer reviewed this and reset it back to free.
    3.) I got an email from TeamViewer stating:
    Dear TeamViewer User,
    Thank you for getting in touch with us. We are happy to inform you that your TeamViewer ID has been reset to “free”. After reviewing your request, we decided that your use case can be qualified as “personal”.
    However, after uninstalling/reinstalling via the "free option", rebooting several times, it still showed "Trial expired" on that laptop. I had to have my wife get on that computer and extend the trial just so I could get on today. How can I get this resolved? I feel like I provided proof via the appropriate channels and now I am getting actually upset over this and I shouldn't be.
    Note: I do see a similar topic and put a sales ticket in, is there anything else I need to try and do?
  • IgorZ
    IgorZ Posts: 5
    There is news, teamviewer host on rasspberry pi works ONLY when an external HDMI device is connected. Without an HDMI device, teamviewer host cannot find the connection to the Internet. Interestingly, the teamviewer host developers know about this problem? :)))
  • I had the same thing happen to me. I submitted the form initially in early August, then a month later and then a month after that. Absolutely no response either YES or NO.
    I use the product 100% for personal use for family use (grandparents primarily), and sometimes to access other computers within the house on the same LAN.
    TV's lack of response and supposed "free personal use" has become a scam. If I don't hear back in a week or so, I'm moving to an alternative product.
  • Although I can appreciate an answer to my issue more than likely being in this thread, I don't have time to sift through all of them to try and find it.
    Can someone please explain to me why I have been getting the following message and how to get rid of this issue:
    Why do I see 'Commercial use suspected' / 'Commercial use detected'
    I am using TeamViewer for personal use (no financial gain, no commercial usage) and I have recently begun to get these messages.
    Please advise.
    Thanks.
    H Rose Jr
