Demo Version Error Message
Why do I get this error? I'm connecting to a server that is using a customized QuickSupport app. It's the only way the software vendor allows connection. I'm only able to stay on 5 minutes and then it times out.
Thanks.
  • Reyhan
    Dear @fmoladavis
    You get this message, because you make connections to customized moduls with your free TeamViewer version.
    You need a commercial license to remote server systems or for connections to customized Quick-Support or Host moduls. Therefore, termination after 5 minutes is an expected behavior.
    In case you are interested in buying a commercial license or have any questions please do not hesitate to contact our salesteam any time here
    Best regards.
    Reyhan
    Reyhan
  • starfoxed64
    @Reyhan wrote:
    Dear @fmoladavis
    Best regards.
    Reyhan
    Okay so is there a specific download for users who are using the free version? If so, can you please provide the link. I use TeamViewer for personal use on my personal devices only and the message and time limit is very frsutrating. I have not had this issue in the past.
    Thank you for your support! Still love your product.
  • Georgevdley
    Georgevdley Posts: 2 ✭✭
    my account is licensend and i still got this problem. I uninstalled Teamviewer several times, I cleaned ones the Registry, nothing helps. I am getting so mad about this I did not installed teamviewer anymore.
  • Esther
    Hi @Georgevdley
    Thanks for your post.
    Are you logged in to the Computers & Contacts list with your licensed account when getting the message?
    Thanks and best,
    Esther
  • Georgevdley
    Yes, my account was privat but is now changed into commercial
    @Esther wrote:
    Hi @Georgevdley
    Thanks and best,
    Esther
  • Esther
    Ok - great to hear! Thanks @Georgevdley !
