Version out-of-date: Update the remote Teamviewer
My flavor of this problem was: using current full version of TV on a PC, and using Quick Support for Mac on remote. On connect, got message that remote needed an update.
If only the system had allowed me to connect, in order to perform the update! The update instructions don't work for Quick Support, which doesn't have an update option in its help menu. So instead had to coach my 90 yr old mother on finding, downloading and installing the latest version, without being able to see: so difficult and time consuming!
After update to latest version of Quick Support, STILL got the message. Came here, read this and other threads, got frustrated, searched for alternatives. Surprised to learn that Chrome browser offers a remote assist tool.
[Removed per Community Guidelines] Uninstalled TV both ends.
Has TeamViewer considered improving the dialogue prompt? As a licensed user of TV 12, it caused a lot of hassle until I figured out I just needed to be logged-in to TV. I use the same TV app to provide friends quick support as I do for work PC's. In the past, you never needed to be logged in to do this. You justed needed their ID and password.
Perhaps the dialogue could indicate that logging in is a possible solution? Also, provide a Cancel button on the dialogue please.
yes... magically transport yourself to the other side of the globe to admin a machine that you installed TV on to be able to do remotely!
Incredible short sidedness by TV!
(also no i dont use auto updates because I like to test stuff deployed on remote machines before i use it.)
OK, I think that last nag-action did it for me: I will try **Third Party Product**.
I used TeamViewer mostly to help my remote mother. Up to TeamViewer 11 (since some versions before) there was this (free) feature to block the user imput. Very important with helping people who cannot stop to move the mouse etc. That for, I had installed TV11 on my mothers Computer, as Admin and she is working as normal user. I disabled updates to keep v11 there. Now I cannot connect anymore (even not if I use TV11 as well).
My next visit will be only in months, so till then I cannot help her (no, she is not able to install an update etc.).Goodbye TeamViewer, I followed your business policy from v3 to now, it went worse and worse. I had several "Commercial use detected" attacks from you, now this.
Now it is enough.frank
This new update is useless.
I have an older version of the iMac, which makes it impossible for me to update the iOS system and without it I can't update to the newer version of Teamviewer.
My macbook is compatible but I can't even use it to login to my iMac due to this version out-of-date problem.
The remote TeamViewer is running an old version which is out of date
This refused me to connect to the remote machine. With Error : Unknown
Can you please update the TeamViewer to the latest version on both sides?
The point of a remote control app is to remotely manage remote machines. Unfortunatley this update killed the ability to manage remote machines, even for Team Viewer update purposes.
At a company level we are global positioned aka..... remote machines.
The company (2300 employees so reasonable!) took the decision to remove TeamViewer as a solution due to this.
On a personal note, my family lives 5000 miles away in Europe, I personally cannot update the machines from the US I have to wait until i next visit them. I also plan to remove TeamViewer on a personal tool basis.
Once you are their just update? Yes I could, but I no longer trust TeamViewers management to do the right thing and not screw me again in the future. I'm sure this experience taught them something, but I havent even seen a public recognition of the issue... At least Sonos put their hand up and admitted they had made an error when they suggested a similar direction...
Way to go on breaking a good product. This new license model stinks and there too frequent upgrades forcing us to upgrade everything. This is not feasible. Way to go Teamviewer on forcing us to look for an alternative product due to idiocracy policy decisions. Prior to TV 13 everything was perfect. we could upgrade when it was right for us not for you. And now a yearly subscription model with as many upgrades to new versions making Microsoft Windows Feature updates look slow. You should fire whoever made this decision and bring back the good old Teamviewer company that made you great in the first place. Now you've gone to **bleep**
I found a good alternative, by searching on line. Previoulsy, when I posted the name of the alternative in these messages, such messages were deleted by the "though police" that operate the web-site. Another example of how to destroy one's reputation.
and were you able to create a vpn remotely or not?(without the help of a person I mean)
To EagleFlyFree: I am not sure exactly what you mean by your question, so let me answer it like this: The desktop App that I found provides for Unattended Remote Access, after setting it up for same with a password for remote access. So from my desktop, I click on a target machine and it automatically logs on to that computer, and then I have complete remote control, just like being at the remote desktop. I can operate the remote machine and do file transfers both ways. It can also be configured for non-unattended access, so that somebody needs to allow access. When I close down the connection, it automatically disconnects. The only bug with this App is the way it handles keystrokes that I send to it. There are 2 or 3 ways to allow keys to be interpreted, and some modes block some keys (for some reason). Try a Yahoo search for "unattended desktop help center" and see what you can find. Sorry that I am restricted from telling you what App I found. Garry Anderson at shaw dot ca.
I am getting this message too. I try to help a family member (age 94!) and updated TeamViewer on her Mac from version 9 to 12, the latest her computer can run. It cannot update further! I tried version 12 on my Mac, the oldest version I can run. Her TeamViewer ID seems to be prompting us to update TeamViewer, but that's not possible. The ID didn't change when I uninstalled the old version and reinstalled the new one, or when I deleted her account and logged in as me, or when I installed TeamViewer Host. How can I help her without buying a new computer that will run the latest version? Thanks.
Did you try an older version of **Third Party Product** already? I guess your family member might have OS X 10.9 (OS versions). [removed per Community Guidelines]
In any case VNC must work, there are several clients for it and the VNC protocol didn't change since. With a repeater you can pass through the router's firewall but this is a bit tricky to install. But if your family member can press a button than a port forwarding will do it already.
Good luck, frank
PS.: TeamViewer is not very confident about their product. If I mention in this forum some other, concurrent product, they will automatically delete the name, so I had to mask it, see above **Third Party Product**. Look what happens if i write it in clear: **Third Party Product**
No offense here but isn't the point of Teamviewer to give remote support? If the other person has a virus or a full hard disk, etc which happens more frequently than you might think then they won't be able to receive remote support because of this " you have to update" implementation which eliminates the point of providing remote support in the first place. I'm surprised that TeamViewer developers would implement such an awful feature. In fact it's preventing me from purchasing TeamViewer to use for my business because if it's not something that I can just click and connect with without the other person's interaction then it's not really that useful for me.
Greetings,
TV is mistakenly giving an incorrect warning because it wrongly thinks the remote computer is running a different version. The message is:
"The remote TeamViewer is running an old version which is out of date. Therefore, you can not connect to this version anymore."
I was at the remote computer's location yesterday, and updated TeamViewer 14 to the latest version 14.7.48298. I verified this version number after the install by using Apple's "get info" feature, which shows any file's version number.
Today, I used the same .dmg installer to update Teamviewer 14 on my non-remote computer to the identical version 14.7.48298 (also verified). Yet when I launch TV on the non-remote computer, I get the aforementioned warning message, which is clearly incorrect.
Any ideas? Both computers are running Mac OS 10.12.6. Both versions of TV are the free one.
I am afraid this "solution" was of no help at all. I have appreciated the use of Teamviewer to remotely support my elderly father for several years now, but it has just stopped working.
Even though we are both running the exact same Version 14.7.48298, from May 28, 2020, on Mac laptops , I can no longer connect and instead receive the Version out-of-date: Update the remote Teamviewer error message. Is this a software bug? Is there any solution or workout available?
Any help you may be able to offer would be greatly appreciated. Thank You
I am using Windows XP service pack3, when i try to connect to another device I get two messages (windows): "Version out-of-date:Update the remote TeamViewer" and "Impossibile to connect, unknown cause".
Before that, just a week ago, I could connect but just for 5 minutes. That's started more or less a few months ago.
TeamViewer version is 14.2.56676 on both devices (the controlled one is running Windows 10).
May you do anything?
I'm trying to connect to a Windows XP machine (TeamViewer V14.2) from Windows 10 machine (TeamViewer V15.11.6) and constantly receive an error message which says that the remote TeamViewer version must be updated however as the other machine runs on Windows XP later versions are not supported. how can I solve this issue?0 -
Teamviewer Loop: I try to log in to my remote device > "Version is out of date..." I have to update the remote device in order to access it > I can't log in to the remote device because it's not updated so I can't update it.
They've taken what use to be just a challenge and made it impossible. I used to use it so I can access a device remotely. They don't have a method to update devices that you can't access, but they force you to update to connect. They have a "web interface" that is unusable because Google is phasing out their Chrome app.
And they think this is fine. There's never a helpful response. I don't even use Teamviewer anymore.
