end message with TeamViewer Remote Access
I'm using the free version to access another PC. When I finish the session a popup window appears on the other PC saying something like This was a TeamViewer Session etc.
The problem is that when I leave the session this popup window interferes with the program I'm running on the other PC.
If I upgrade to the Remote Access licence, can you tell me if there a popup window left when I leave a session? I want to be able to leave the other PC without the popup  showing.
Thanks!
  • VatsilidisVatsilidis Posts: 659 Star
    Hi @arathra
    You can disable this comment box to the remote PC with the help of this post here
    Thank you for posting and best regards
    Pro
  • Yuri_TYuri_T Posts: 1,743 Moderator
    Hi @arathra ,
    Could you please provide me the exact message in order to understand your situation more?
    The free version of TeamViewer has a three-hour limit on its connections. This means each session will be disconnected after three hours. However you can always establish a new connection again immediately afterwards.
    Please note that licensed versions of TeamViewer do not have any time limit on their connections. If you have a need for unlimited connections, please consider purchasing a license. We will be happy to discuss our licensing options with you and give you a personalized quotation.
    If you are interested in TeamViewer licenses, please feel free to contact us.
    Kind regards,
    Yuri
    Community Moderator
    コミュニティモデレーター
  • arathraarathra Posts: 2
    Thanks, @Christoph - that's what I wanted to know. Cheers.
