change licence according to my id
monoludo
Hi
I have a problem over the teamviewer, installed on my parent's computer. They have installed teamviewer with the option commercial and no purchase license after
Now the evualation period is over, how can i switch to a personnal installation . I have uninstall and install with personnal use , but no change i have the message that the trial period is finish
thanks for your help
Hello @monoludo
Thank you for your message. ?
You will find all the information you need in our Knowledge Base article here: Why do I see TeamViewer trial - 'Your trial period has expired' ?
Best regards
