Cannot connect until login to teamviewer website
When I try to login from my teamviewer client, nothing happens when I try to connect. I have to login to the teamviewer website and connect from there. Once I do that, the client login from my pc successfully connects. Anyone else experiencing this? Any suggestions?
Best Answers
Hi MRE,
Thank you for your post!
Sorry you are having trouble logging into your account. You mentioned "When I try to login from my teamviewer client, nothing happens when I try to connect."
When you open TeamViewer, is your sign in credentials already populated as pictured below?
If yes, please try removing the password the entering it again and sign in. This should resolve your issue and if it does please accept this as a solution.
Hope this helps!
Jonathan
6 -
Thanks for your help. This seems to have cured my problem.
5
Hi MRE,
Hope this helps!
Jonathan
6 -
5 -
My problem similar, but not solved with remove the field and type again, the signin button still grey out. Any suggestion ?
my login button is greyed out and re-entering the password does not free it uup.. any ideas?
I had to log into the website and add my machine to the list of trusted devices again. Once that was done, the log in button on the app worked again.
Same issue - desktop client don't connect even though I am on internet typing this? Did you get answer?
