can't connect to the computer
I need to remote control a computer. I get the ID and input it under the partner ID , click on " Connect to partner". Then on the bottom of TeamViewer shows "Connecting". I waited for a few minutes, then the status just changes to  "Ready to connect(secure connection)".
It doesn't connect to the computer without any error message. I've tried many times but all failed. What's wrong with it ?
  • louise
    louise Posts: 2
    Any help?
  • qaking
    qaking Posts: 1
    Try looking in the log file, under the "Extras" drop down menu.
    Here is an example of what I see when I silently fail to connect to a partner:
    2017/06/21 10:42:45.743 2992 3032 S0! TcpCarrierBase[16]::SendCompleteQueue(): No Connections, Type_Tcp, Dir_Outgoing, Ending 0, SendQueue 1, CurrentSendQueue 0, SendCache 0
    2017/06/21 10:42:45.743 2992 3032 S0 Activating Router carrier
    2017/06/21 10:42:45.743 2992 3032 S0 CommandHandlerRouting[17]::CreateActiveSession(): outgoing session to 222608391 via server25601.teamviewer.com, protocol Tcp
    2017/06/21 10:42:45.744 2992 3032 S0 Carrier[16]::EndCarrierInternal(): ClientID: 0 SupportsEndSession: 0, SupportsCCmd2: 0, SessionType_MasterConnect, SendQueue: 0 (4 Bytes), CurrentSendQueue: 0 (0 Bytes), SendCache: 0 (0 Bytes)
    2017/06/21 10:42:48.576 2992 3032 S0 IProcessCommandHandler[17]::CmdEndSession(): Received CMD_ENDSESSION with reason: 3
    2017/06/21 10:42:48.711 2992 3048 S0! Carrier[17]::EndCarrierInternal: Discarded 1 commands, ClientID 222608391, ShutdownGracefully 1, SessionType_RoutingSession
    2017/06/21 10:42:48.711 2992 3048 S0 CGatewaySession[17]::EndSession(): Session to 222608391 ended. Estimated capacity=0kBit/s, Latency=0ms
    2017/06/21 10:42:48.711 5148 448 G1 LoginOutgoing: Terminated by client
    2017/06/21 10:42:48.711 2992 3048 S0 CSendCommandToMaster::SendBCommandToMaster: CC=3 CT=91
    2017/06/21 10:42:48.711 2992 3048 S0 UDP: create udp connection was not successful: UdpHolePuncher shutting down: (*)
    2017/06/21 10:42:48.711 2992 3032 S0! RemoteSession[17]::AddRequestedCarrier(): request carrier UdpToPartner failed!
    2017/06/21 10:42:53.712 2992 3032 S0!! SessionControl::SessionCloseTimedOut: Session 1027966149 wasn't closed in time!
  • lsamaha
    lsamaha Posts: 2
    Looks essentially the same:
    2017/08/07 16:12:08.147 9828 9900 S0 IProcessCommandHandler[9]::CmdEndSession(): Received CMD_ENDSESSION with reason: 3
    2017/08/07 16:12:08.194 10736 7804 G1 LoginOutgoing: Terminated by client
    2017/08/07 16:12:08.194 9828 9904 S0 CGatewaySession[9]::EndSession(): Session to 340874704 ended. Estimated capacity=0kBit/s, Latency=0ms
    2017/08/07 16:12:08.194 9828 9904 S0 UDP: create udp connection was not successful: UdpHolePuncher shutting down: (*)
  • Frost
    Frost Posts: 1
    <Necro> but I don't see any resolutions about this issue being posted and I'm getting a similar issue.
    from the log "Received CMD_ENDSESSION with reason: 3"
  • vahid-dan
    vahid-dan Posts: 1
    Hi;
    I have the same issue. Any solution yet?
    Bests,
    Vahid
  • Me too.
    Log says:
    2020/04/04 16:25:12.952 6490 **Please do not post TeamViewer IDs**67200 S UDPv4: [34]: create udp connection was not successful: UdpHolePuncher shutting down: (*)
    2020/04/04 16:25:12.952 6490 **Please do not post TeamViewer IDs**67200 S UDPv6: [34]: create udp connection was not successful: UdpHolePuncher shutting down: (*)
    2020/04/04 16:25:12.952 6490 **Please do not post TeamViewer IDs**67200 S! RemoteSession[34]::AddRequestedCarrier(): request carrier UdpToPartner failed!
