How do Set Team Viewer Screen fit to my screen?
Gta
Hello @Gta,
I recommend you to try the three scaling buttons on the left side of the View panel and find out which one fits the best on your local screen:
I hope this could help. ?
Best regards
French Community Moderator0 -
@JeanK Yes, i tried that but no use, still the same size. Is any setting change from end-user Teamviewer settings.
@JeanK wrote:Hello @Gta,
Best regards
