Highlighted
Posted by jimbobguate
Henagon
"The partner does accept incoming connections" error in MS Store version of TV
Subj: "The partner does accept incoming connections" error in MS Store version of TV
When I try to remote into a friend's computer I get the error message:
I know that in the "full" EXE version of TV you have to go to:
OPTIONS --> ADVANCED OPTIONS --> SET: ALLOW FULL ACCESS
In the Microsoft Store app. version I can not find the advanced options settings.
How to I fix this?
THANKS!
JIm
1 Reply
1 Reply
Highlighted
Henagon
Re: "The partner does accept incoming connections" error in MS Store version of TV
I was trying to help my sister with an issue remotely last night and we could NOT get a connection from my MS store version of TV to hers....
I had her install the "full" version of TV on her machine and "presto" no problems after that....
Not a fix of course, but at least a work-around ... we did not try control in the other direcdtion to see if she could remote into my machine ... we ran out of time.
