Hello. This terminal only supports screen sharing, I want to fully control the Android terminal remotely. Information about the device HUAWEI MATE 9 MHA - L29 android 7.0 Please enable this.
I have the same problem with my Huawei Y560 model.
Anyone helps ?
please check this thread for further information and download the app from Google Play.
I hope, this will solve the issues :-)
All the best, Esther
Ok, then unfortunately I suspect that the Huawei device you are using is like my Dad's Xoom and does not support remote control.
Can you elaborate on this part please " but if add-on does not match the version, I get an indication and ask for uninstallation of add -on. "
Try installing the Android Host instead of QS
