How can I lock the phone after connecting to an Android phone and finifhing the work. I will need to come back an unlock ot again.
Currently the phone display stays on after use and there is no way to lock it and let the screen go dark.
How can you leave your phone screen on when you access it remotely!
I had similar problem with dropbox that when the phone goes to sleep it wont sync anymore.
I dont know whether these guys are dumb or just slow? People in computer field use to be real smart.
I'm facing the same problem.This is a valid issue, yet no feedback about it?
EDIT:@amirf: as an alternative I found that I can lock the phone using android.com/find.
