Posted by kingkoton
Electron
[Android][Google Nexus 7 2013]: Remote control not supported from a Win10 PC?
I tried to use teamviewer Host with a google nexus 7 2013 tablet.
The installation from the playstore works properly.
I can connect properly to the tablet to see the screen.
When I try to click, a blue hand is displayed at the exact place I click, but the nothing is sent to the tablet (No remote control)
Do you know how to fix this issue?
It is very frustrating to see the screen with be able to remote control the tablet.
Many thanks in advance for your help.
Kind regards
1 Reply
1 Reply
Posted by ebeighe
Digon
Re: [Android][Google Nexus 7 2013]: Remote control not supported from a Win10 PC?
The same thing happened with my Nexus 7 tablet (Android 6).
Screen sharing works, but no remote control.
