Can't control my phone with QuickSupport
Highlighted
Posted by
Henagon
I want to remote control my cellphone
I installed QuickSupport on my phone (Android 5.1) which was already rooted
Teamviewer on my PC (win7 X64) version 12.0.71503
When I connect to my phone , a messeage "You partner rejected your connection request" display above . But I Confirmed on my phone.
After that ,a session established, I can send message between my PC and my phone.
But I can't remote control my phone
1 Accepted Solution
Accepted Solutions
Highlighted
Posted by
Tetragon
Solution
Re: Can't control my phone with QuickSupport
You need a add-on that matches your device. Quicksupport should ask you to download it, if one is available. It might be possible that there is no add-on for your device. There is a list of supported devices, but i think this list is not complete or up to date, as at least my device, which can be controlled, is missing. (My device was on this list, when it wasn't supported, now that it is supported, it isn't on this list anymore ?!?!)
»We are all born unique, but most of us will die as a copy.«
View solution in original post
Highlighted
Posted by
Tetragon
Solution
Highlighted
Posted by
Henagon
I see.
My device is HuaWei which is not on the supported list.
Highlighted
Posted by
Tetragon
My Devices are Huawei/Honor 7/8.
There is finally an official add-on in the Play Store.
There was already an unofficial version before the above release, which worked well. It was originally from TeamViewer too, but for some reason they removed it from Play Store. You can still find it as .apk-file through google.
Highlighted
Posted by
Henagon
Hi
The addon doesn't seem to be valid for Honor 8 phones on nougat. I get a message saying the addon is not compatible.
Is there any way we can remotely control an Honor 8 on Nougat without rooting it?
Highlighted
Posted by
Henagon
I would also like to know how to remote control the honor 8 lite with Teamviewer ....
Has anyone managed to get this to work on Nougat??
Highlighted
Posted by
Photon
My mobile is micromax a120
Highlighted
Posted by
Electron
I have Motorola E3 Power mobile phone. I am not able to remotely access my phone. It is only working with screen sharing mode. Please help.
Highlighted
Posted by
Photon
hi, i need add-on for Oppo phone. where can i find it?
Highlighted
Posted by
Henagon
I also bought XZ premium cause sony is in the list support but i can't control device and the screen showed the message  "this device only supports screen sharing mode".
Highlighted
Posted by
Henagon
Is there any add on for vivo y51l
