Announcements
Universal add-on for Android has been released. Learn more.
Highlighted
Posted by
Digon
Teamviewer 14 and iOS12.3.1 firmware limitations
I have an iPad Air with iOS 12.3.1 and have installed TeamViewer14 and Quicksupport
I can connect the computer and the iPad, but the remote control doesn't work, because of firmware limitations. What is this about, and how can I activate the remote control?
2 Accepted Solutions
Accepted Solutions
Highlighted
Posted by Moderator Moderator
Moderator
Solution
Re: Teamviewer 14 and iOS12.3.1 firmware limitations
Hello @tastom,
With an iPad you can connect and remote control a computer (PC or MacOS).
If it is a MacOS using Mojave, feel free to check this article to allow remote control: How to control a Mac running macOS 10.14 Mojave
However, with this same iPad, you cannot control an iPhone or another iPad.
For iOs device, only screen sharing is available.
French Community Moderator
Did my reply answer your question ? Accept it as a solution to help others.
Find this helpful ? Say thanks by clicking on the Thumbs Up button.
View solution in original post
Highlighted
Posted by
Digon
Solution
Hi Jean
Thanks alot for your message!
My supporter knew, how to solve my problem, despite the firnware limitations. So, now I can firgure out, how to handle a same situation
Cheers, and thanks again
Tom
Highlighted
Moderator
Solution
Hello @tastom,
Highlighted
Posted by
Digon
my problem is the remote control of the iPad FROM the Wndodws computer. Please advise.
Highlighted
Posted by Senior Moderator Senior Moderator
Senior Moderator
Hi @tastom
As my colleague already mentioned:
This is also applicable if you connect from a Windows device to an iPhone/iPad.
In this article, you will find all relevant information about iOS screen sharing: How can I share the screen on my iPad/iPhone with TeamViewer?
Wish you a great day and all the best,
Natascha
Highlighted
Posted by
Digon
Solution
Hi Jean
Tom
