Does mic and spkr signals transmit between host and remote endpoints?
Hi @skytitan,
Thank you for contacting TeamViewer Community.
It is possible depending on the remote device.
If you are using Mac device on the remote device, the sound and voice function is unbailable due to a manufacture's policy.
If you are using Windows, please kindly to try the following option during remote session.
Remote session toolbar -> Communication -> check the [ computer sound ]
For more details regarding remote session toolbar, feel free to check the knowledge article from here.
Hope this would be helpful.
Best Regards,
Akiho
