I am connecting from a Windows 10 system to a couple of Android phones, S9 and S10+.
Every once and while, it will respond, but generally, no.
What do I need to do to get this working?
Hi @ClayGoss,
Thank you for contacting TeamViewer Community.
Please reply this message with a screenshot of error message ?
Meanwhile, would you please update both devices and TeamViewer itself to the latest version?
Also, please kindly to check the knowledge article - Why Can't I Control my Android Device? and Universal Add-On for Android.
Thank you for your understanding and patience.
Best Regards,
Akiho
I see now that the interface is off register.
