Add support for Ubuntu Server 20.04 LTS 64-bit on Raspberry Pi (aarch)
Ubuntu Server 20.04 LTS supports 64-bit on Raspberry Pi. However, the architecture is aarch and when attempting to install TeamViewer it will not run as this is not supported.
Please add support for this: https://ubuntu.com/download/raspberry-pi
The GUI environment used for this test was Ubuntu Desktop.
Tech Support IoT
Hi
I would like to test it as well. Can you send me the link to the 64 bit test version?
My system:
Linux raspberrypi 5.4.42-v8+ #1319 SMP PREEMPT Wed May 20 14:18:56 BST 2020 aarch64 GNU/Linux
Kind regards
Peter
Tech Support IoT
Hello, I would also like to test this as I'm in the exact same situation. Could you also share it with me?
Hi
I use this os version on a raspberry pi 8GB but there is no *.deb version for this available.
uname -a
Linux raspberrypi8gb 5.4.42-v8+ #1319 SMP PREEMPT Wed May 20 14:18:56 BST 2020 aarch64 GNU/LinuxRegards
Peter
Hi @lmcal6
The aarch64 package is for the TeamViewer IoT Agent and is different in features from normal (host) TeamViewer App. If you want, I can send it for testing. More information about TeamViewer IoT here
Mircea
Tech Support IoT
YEs I would like to have it for testing, thank you.
Tech Support IoT
Hi
Thx!!
As I know there is no Teamviewer version available which allows to share your Desktop.
Peter0 -
in the previous post,someone talk about a "test version" sent in pm
Tech Support IoT
I'd also like to test the version for the Pi4 running 64-bit Ubuntu Server 20.04 LTS
John
Hi @seanty
Mircea
Tech Support IoT
Hello mircea_c
Please send me the test version as well. I am running a RPi4 64bit and I would like to give it a try since nothing else works.
Thank you!
Tech Support IoT
Does this version work on Ubuntu 20.10?
Hi @Alastar
The IoT Agent should run on Ubuntu 20.10 on aarch64.
Please take in consideration that the Agent has different features and use than TeamViewer Host Module.
Mircea
Tech Support IoT
Also having this issue. Can you send the testing version?
David
Hi @dha-hc
The testing version for aarch64 it is for the Teamviewer IoT Agent which have different feature that Teamviewer Host.
Mircea
Tech Support IoT
Can I get a download link as well? Running Ubuntu Desktop 20.10 x64 on an RPi 4
Hi @mircea_c,
Is there a beta version of the TeamViewer Host for arm64 (Raspberry Pi4 running Ubuntu 20.10) I could possibly try?
Kind regards,
Eleftherios
Hi @Eleftherios
Unfortunately, this is not ready yet.
We will announce on the community when it will be available.
Mircea
Tech Support IoT
Mircea
Tech Support IoT
Hi @Jorn123
The IoT Agent should also work for Ubuntu20.10 on this architecture ARMv5hf, ARMv7hf, X86, X86-64
You can login on the teamviewer-iot.com and click on "Add device" select "Debian" and select "Custom Installation"
Please keep is mind that this is not the Teamviewer Host (used for remote control)
Mircea
Tech Support IoT
