1287288290292293431
  • Steve_F50
    Steve_F50 Posts: 4
    I entered my id's individually clicking the + after each one, the printed form showed each id separated by a comma and no spaces. I guess they could all be pasted in as csv's
  • goblinsly
    goblinsly Posts: 1
    I am having trouble with comerial use also. I sent the form days ago, i even added my ID card, but no response yet. So i am asking, first, how fast did they answer your form usualy and second, where did they reply ? As for why it detected false positive in my case, i have no idea. I only use teamviewer to connect to my home pcs and occasionaly help my dad with his computer
  • Billr_57
    Billr_57 Posts: 2
    My connection times out saying I am still using TeamViewer as a commercial user and I am not, was email and told it was fixed but it's not....
    I am requesting you fix that please
  • EdwardUK
    EdwardUK Posts: 47
    They send a response within two days to several weeks. They send the response to the email address you used.
    Yes the process Teamviewer use for commercial detection is creating many false positives. This thread is evidence of that.
  • EdwardUK
    EdwardUK Posts: 47
    Probably Teamviewer reset the wrong ID (they seem to be doing that a lot). Only recourse you have is to send in another request and hope they get it correct the second time round.
    Also make sure the IDs you are connecting to have not themselves been deemed commercial. If so, and assuming they are not actually commercial, you need to send in their IDs for a reset as well.
  • FuzzmanKs
    FuzzmanKs Posts: 54
    Did you enter the TV ID WITHOUT SPACES? I'd recommend you also list up to 10 ID's to be reset.
  • FuzzmanKs
    FuzzmanKs Posts: 54
    I think if you put any spaces in that field (including after the comma) then it missed the other ID's. My copy of the PDF showed 6 ID's with no spaces anywhere in that field.
  • tonyhoon70
    tonyhoon70 Posts: 1
    I am a non-commercial user. I just started using teamviewer yesterday in a several months. And, today, I had to connect my remote PC in the morning, but I saw the popup message says my usage time is limited and it could be used again a few minutes later.
    I saw such message for the first time. Is that your new plan for non-commercial users?
    If so, how much is my time limit allowed on one remote connection?
  • FuzzmanKs
    FuzzmanKs Posts: 54
    That is not allowed for personal/private use. The work network will (apparently) keep triggering the commercial use block. See the blog that has the details in the first post in this thread.
  • FuzzmanKs
    FuzzmanKs Posts: 54
    It sounds like you use a cell/smartphone to connect to computers? Do you have a PDF creater / reader app on your smartphone or device you are using when you try to create the PDF? I also just read yesterday on Teamviewers Support twitter account that electronic signatures are an acceptable way to sign the PDF you are creating. It did not define if the signiture could be printed characters or needs to be an image of your signature. So I assume it will accept typing in your name.
  • Said to hear I'm not the only one.
    Seeing as I often login on the website, I haven't been able to find an ID for that computer. I also assumed that my ID would stay the same if I just use the Teamviewer website. Anybody know if that's true? Or do you get a new ID for every other computer you use to login on the Teamviewer website?
  • Edoco
    Edoco Posts: 2
    Hello i would like if there is some from support who can help me,
    i can't send a support ticket;
    my problem is that when i start a connect with a computer it show me up a message i finished my free time and it ll disconnect soon,
    but it show me that when i didn't use it during the all day,
    it's looks like it counting my usage time wrongly
    thanks for support
  • TimAllen
    TimAllen Posts: 1
    when i try to connect to my sisters pc, the connection lasts about 5 seconds then ends - any suggestions ?
    I'm on a free personal subscription
    Tim
  • MarcinSz
    MarcinSz Posts: 0
    How to spread the session limit time-out? I have free version and usong it non-commercial mode (to help my disabled Sister to manage Her computer
  • kmcphotog
    kmcphotog Posts: 1
    I have sent in the form a few times regarding non commercial use...and have been approved...however I keep getting booted off...should I unistall and reinstall? not sure how to solve this problem
  • apvofc
    apvofc Posts: 1
    I am having the same problem - the "pdf" button remains "grayed out", and I cannot download the file. Nothing appears to have downloaded automatically. Still have this problem - Not seeing a solution here, either.
  • I've been trying to utilize Reset Management page for 8 months now, but clicking the Generate PDF button only adds a carriage return to the Memo field without doing anything else, and additional clicks have no response in Edge (PC), Internet Explorer 11, and Chrome.
    Is there any other mechanism for submitting or emailing a JPEG of PDF capture of the Reset Management page to Technical Support?
    It's unbelievable that this problem has been reported by so many people and page has not worked for so long! Please Help!
  • Freem
    Freem Posts: 1
    edited May 2021
    Hello.
    When you fix error "The license limits the maximum session duration for the partner" for free license?
    I haven't been able to connect anywhere for months. It looks like you will have to switch to your competitors ' app((🤨
    It's unbearable. Previously, TeamViewer was more stable.
  • Zvika
    Zvika Posts: 1
    I keep getting messages that commercial used discovered, and sessions are stopped, while I am just using personal use.
    What should I do?
  • FuzzmanKs
    FuzzmanKs Posts: 54
    Scroll back up a couple of days and you will find the procedure to get it hopefully corrected (reset).
  • This content has been removed.
  • FuzzmanKs
    FuzzmanKs Posts: 54
    No. Support says that does not work. If you read the blog mentioned in the first post of this thread you might find a hint as to what you might be doing to trigger the block.
  • Andrea1234
    Andrea1234 Posts: 1
    I connect with my mobile to my home pc, and TW says that they discovered that my account is a business account.why?
  • sdf
    sdf Posts: 2
    I'm using the program to help my mother with the stuff she needs help in her computer. Connection gets disconnected instantly and says me to upgrade. But, I'm trying to use it for personal stuff. I tried to find a way to submit a ticket. But it's impossible. It is so impossible that there's a website inside of this website to show how to submit a ticket. https://community.teamviewer.com/English/kb/articles/72027-how-to-submit-a-ticket which is outdated. Can someone help me with my problem?
  • sdf
    sdf Posts: 2
    The dialog that i'm getting...
  • ShaGan
    ShaGan Posts: 1
    I have the same issue... my connection was disconnected after few seconds. I use team viewer from years to help my parents and to control my second computer and always use personal... Now i need to spend 30minutes to explain parents what they need to do on Quick Help windows app which it's annoying us...
  • Byter
    Byter Posts: 1
    Dear sirs, I also use teamViewer on my iPad. There I get only (very) limited time to use teamViewer as where on my desktop and laptop computers I can use teamviewer for a couple of hours if need be.
    Is there somthing |I do wrong?
    Rgds,
    Henk van der Heijden.
  • drogg
    drogg Posts: 1
    edited March 2022
    What's all this about commercial use?
    I've been using Teamviewer for a long time to connect to upstairs, my daughter, and my mother in laws Android tablet in Austria.
    Recently can't do anything as I keep getting time out/ Commercial use message.
    This is impossible.
    **bleep** is going on?
