Operating system: Windows
Version: 15.41.9
Release date: 2023-05-04
Actually it's not Windows. Even when I do as you guide, it still is muting or turning my sound down a lot. So this certainly didn't help. Any other suggestions ?
@PaulOtto @michabbb Indeed, the meeting functionality is no longer available for free users.
However, you can still use TeamViewer Meeting with the dedicated Meeting client.
You can download the Meeting client here: https://www.teamviewer.com/en/download/
@PaulOtto The Windows authentication functionality is now available with version v15.42.5. Please make sure to update your clients.
Device groups are still available for licensed users. If you can't see your devices, it most probably means that you haven't updated your devices yet. Please see how to update your devices here: Update your devices
I hope this could help.
If not, do not hesitate to ask further questions here. 🙂
/JeanK
AGREE !!!!!!!!!!!!!!!!!
"meetings" is the **bleep** reason I am using this software and now it´s gone in the new UI ? **bleep** !?!?!?!?!?!
When controlling to some older Windows 7 machines , with a variety somwehat older versions
after this update on the control side EVERYTHING , I MEAN EVERYTHING, IS SLOWED DOWN (resonse to keys and clicks) and CPU on teamviewer
Was the wake on lan issue resolved?
the TeamViewer updater still forcefully enables and starts the TeamViewer service, with NT AUTHORITY\SYSTEM rights, even if it finds that the service was disabled on purpose and the checkbox for "Start TeamViewer with Windows" is also disabled in the Options.
That's actually windows.
Windows + R -> control mmsys.cpl sounds
Then select "Communications" and select "Do nothing"
There is a problem that bothers me. After updating the new version, when I initiate a remote session connection, the volume of my computer will automatically decrease, and the sound will return to normal after exiting the remote session.
The entire version from 14.41.8 is a bug. A corecture would be very useful.
meeting tab is gone
device groups are missing
unattended access wiped out und needs to be reconfigured
Windows authentication is missing
overinflated
to provide a support you need a third party software
Why?
