sound is reduced
when I remotely connect two PC through Teamviewer, the sound is significantly reduced.
How can I fix this?
As wrote before, I have the same issue, still on unsing the last 15.42.5 version.
@JeanK , disabling the communications' manager of the audio is not a solution.
I want windows able to manage audio when a communication is on, I have a softphone and some other communication's apps.
Why TeamViewer open a communication session when just a remote session is started? Why it enables my microphone too?
I think, as in older versions of TV, the communications should be managed just in case we need of them (sound monitor, conference and so on).
I can't update to the last TV version on my main PC due to the audio management.
Does it help if you turn off the "Computer sound" while connected to a client in the optionsbar at top?
You can also turn off Teamviewer sound in volumecontrol in taskbar.
Still the same issues?
