sound is reduced
when I remotely connect two PC through Teamviewer, the sound is significantly reduced.
How can I fix this?
    Hi @jakang78,
    Please find the solution to this here:
    /JeanK
  • vbMizio
    vbMizio Posts: 5 ✭✭
    As wrote before, I have the same issue, still on unsing the last 15.42.5 version.
    @JeanK , disabling the communications' manager of the audio is not a solution.
    I want windows able to manage audio when a communication is on, I have a softphone and some other communication's apps.
    Why TeamViewer open a communication session when just a remote session is started? Why it enables my microphone too?
    I think, as in older versions of TV, the communications should be managed just in case we need of them (sound monitor, conference and so on).
    I can't update to the last TV version on my main PC due to the audio management.
  • elinne
    elinne Posts: 3 ✭✭
    Does it help if you turn off the "Computer sound" while connected to a client in the optionsbar at top?
    You can also turn off Teamviewer sound in volumecontrol in taskbar.
    Still the same issues?
