How to find your log files on Windows & Mac
Sometimes you may be asked to locate your TeamViewer log files and send them to TeamViewer to help solve a problem. You can submit them to us with a ticket from www.teamviewer.com/support.
To find the log files on a Windows or Mac computer:
- Open the TeamViewer window and click Extras > Open Log Files.
- Locate the file called "TeamViewerXX_Logfile.log", where "XX" is your TeamViewer version.
- If there is also a file called "TeamViewerXX_Logfile_OLD.log", please include this too.
Jeremy
Actually, there is not a "Extras" button on my teamviewer. What should I do now?1
Hi @nobelkuo,
"Extras" is not a button in the TeamViewer program - rather, it's one of the menus that you should see at the top of the TeamViewer window, along with the other menus.
If you're using a Mac computer, you will see the menus at the very top of the screen, rather than at the top of the TeamViewer window.
Jeremy
TeamViewer Quality Assurance Engineer1 -
Would it be so hard to list several common locations depending on version and OS? One of the primary reasons for accessing the logs is you can't actually run/use Teamviewer, making this answer useless.
@Brendan that's a good point! You can find the default locations of the log files in our Knowledge Base article on the topic.
Jeremy
TeamViewer Quality Assurance Engineer0
