@GordonSE03 wrote:thank you Andre75, but being that the machine that keeps being locked out is on a Comcast residential connection and as far as we are aware none of the family uses a commercial/business network for connecting to the internet, your answer though enlightening has little to do with his situation. It appears that TeamViewer's algorithm also looks at the time (how long a connection lasts) and content (what is being done on the remote connection.). That is the only way that the above makes sense about commercial use.
Hi @GordonSE03
I understand that, as same as me and everybody, you try to find out something which would make sense. But the fact is there is not. As told before by a user, it is "no rhyme or reason"
I am (I was) using TeamViewer exactly in the same condtions as you, only through private local network, as same as my friends and relatives that I remote control sometimes... Some other users posting on this community use TeamViewer both from (or towards) their home network and office network including their mobile device .. We know that as they explain it, and that's what TeamViewer doesn't want. I understand this expectation so, they can know at least a reason which makes sense,... but I never used it in any other condition but my home private network , from only one computer, and my relatives and friends also use it from home to their private networks (They are no more than 10 persons, I know each of them, even their homes and network as I am the one who went to install and set those, and they all know only a few things about computer (that's why they obviously need my help through TeamViewer !) For all of us, only one device using TeamViewer is connected to our networks... And yet I've been blocked twice ??? and I am still.
You mention a "time limit per session", but I haven't read anything about in TeamViewer terms of policy for "Personal use", anyhow, I seldom used it more than 1 to 3 hours maximum. By the way, I am the one to offline the TeamViewer connection on the distant machine, then I offline my own software, including its service in Windows Task Manager, that I never set running automatically. I didn't configure any machine that I remote control in order tout let TeamViewer running on with Windows... And my help to the others is about maximum 3 or 4 times a month (sometimes it can spend 2 or 3 months without I use it !) So, I don't think that over limit time can be a reason (not for my use at least).
The other reason you mention : (".... and content (what is being done on the remote connection.)." ??? I've never done something illegal or even fobidden by TeamViewer's policy when I remote control somebody. But I want to believe that you are kidding ?... Anyone who would be checking what you do on your private computer, without your ageement, is total illegal, it's a privacy violation ! TeamViewer is an European company, and I'm sure that it will never run a risk to be black listed and severly penalized for such a violation of the law.
I say again that I understand your, same as mine, will to understand why we are blocked ?... That would lead us into madness !... But, I'm sorry, there is no reason that TeamViewer can tell us. No reason mentioned in its terms of policy... Just remaining the hypothesis of deficient algorithm !
But the worst is that the moderators here (even though they are really TeamViewer employees, as told me by Josh, one of them), don't want to communicate about this... They all persist to send us to "the form to fill out"... and they don't hear that we did it yet, but have been blocked again, soon after having been reset... and this reset time takes (it took to me) 1 month !
I hope that @JoshP -moderator- is reading this post.
I would say, if they are really TeamViewer employees they should have a way to inform their boss of this situation ? Why don't they ?... I f they do it, why still no solution ?... if there is one, why don't they tell us ?.... @JoshP, please understand that the only solution that you provide us (fill out the form) is useless as I (and many others) explained here several times. Filling out that form is not a solution for not being blocked again a very few time later, moreover it takes a very long time to get reset.
Should we conclude that TeamViewer don't believe us when we say that we use the software under ALL its terms of policy ? The only way to prove it is ... to "fill out the form" with the log file !!! ad libitum... It doesn't work !
André
Hi @GordonSE03
You mention a "limit time per session", but I haven't read anything about in TeamViewer terms of policy for "Personal use", anyhow, I seldom used it more than 1 to 3 hours maximum. By the way, I am the one to offline the TeamViewer connection on the distant machine, then I offline my own software, including its service in Windows Task Manager, that I never set running automatically. I didn't configure any machine that I remote control in order tout let TeamViewer running on with Windows... And my help to the others is about maximum 3 or 4 times a month (sometimes it can spend 2 or 3 months without I use it !) So, I don't think that over limit time can be a reason (not for my use at least).
Should we conclude that we are not trusted by TeamViewer and its moderators when we say that we use the software under ALL its terms of policy ? Unfortunately, the only way to prove it is ... to "fill out the form" with the log file !!! ... and... ad libitum... It doesn't work !
André
On my locked out machine (I have at least four other machines) I created a virtual box running linux and then loaded TV onto that OS. It's a little klunky but for now, it works. If TV flags that one, I'll create another virtural machine. Once you have the vitural interface set up, it takes just a few minutes of one's time to create a new instance, though the loading of the OS takes about half an hour. This would be the whack-a-mole response where I am the mole.
We should be looking for a new company, anyway, because it is pretty obvious that TV is having financial challenges, (running out of money? preparing to be taken over? general cooking the books? etc?)
(Mr/Mrs/Ms Moderator, you'd should be looking for a new job, too.)
My reply to @GordonSE03 has just got censored !... I wonder why ??? but never mind !
You are too kind to warn those whom their marketing managers are working to make them jobless. But they shouldn't mind too much as they show that they are competiting for the next Nobel Prize in Physics... and they'll get and share it, with no doubt ! So, don't worry too much for them.
Your "wack-and-mole" is interesting, but you know that most of us don't have more than one computer, and our competence in IT doesn't allow us to reach the "klunky" system ! That's why because we liked to use TeamViewer. It was not too complicate for our simple mind ! Anyhow, thanks to provide us a solution which could work better than to "fill out the form"... Why don't you apply for a job on this community ?... At least you will give us more than a single solution ... which's useless or just works for 3 sessions.
Oh, I think I guess why you don't apply for a job here ! You scare it will not last longer than the official reset solution !
Nice evening !
Andre
I have been having this issue since Version 13 came out. Filled out the form multiple times. It gets reset. However, when I filled out the form last time (about a month ago), the option for attaching a log file is missing. Still heard nothing back.2
@JRossi wrote:
I have been having this issue since Version 13 came out. Filled out the form multiple times. It gets reset. However, when I filled out the form last time (about a month ago), the option for attaching a log file is missing. Still heard nothing back.Hi @JRossi
Thank you for your one more information. I feel a bit less lonely.
Andre,
I'm retired and don't have a life. One of my hobbies is undermining greedy management. The frustration we are experiencing here is a direct result of decisions made at the highest level of management. The moderators paid to look at this forum are being exploited. These people must perform "... unworthy or corrupt use of [their] talents for the sake of personal or financial gain." I am truly sorry for the moderators. I truly hope that they can find more satisfying employment.
If enough of the moderators quit, then the highest levels of management will have to pay higher wages to those doing the disgusting tasks (lying to people) required of them. The moderators are only here because of their financial situation.
I used to write scripts for customer support ... until I learned what they were being paid. I told my boss "I'm not doing this any more. You pay them a decent wage and I'll start writing scripts again." I didn't have to write scripts again.
It's greed. You and I and the thousand other people in our situation are trying to do right. We're helping people. We don't get paid, we just make the world a tiny bit happier. In my lifeless life, it is something that brings me a modicom of happiness.
But, greed, pure and simple unmittigated greed, is **bleep** life out of everyone.
Hey! You! Moderator. I am sorry for your life. I'm sorry you can't even say to your boss, "Do you have to be so greedy? Do you know that for every one of these thousand people there are five that are being help, but no longer because of your greed?" Go back to school, do something to better yourself. You're not going to find opportunity, much less, compassion at TV!.
4 -
Hi Old Dude,
I'm retired too and I know all what you say. I think you more say it for others than for me. (I've saved your post before it disappears, but few people will read it, and still fewer will understand what you mean). What's wrong ? To make more and more money is absolutely normal, isn't it ?... What can you do... even what can we do, both you and me ? We are quite lonely and helpless before this situation. The world "works" like this since it's very beginning, even before human beings existence ! Our monkeys ancestors was like that already ! I'm afraid that we are just p...ing against the wind...
The moderators are exploited, we should say victims, but at the same time, they are the accomplices of those who exploit them. They are not aware of this, and even seem very proud of the power they are given. They really believe that they have power and they use it to give themselves the illusion of existence. That is basically what dictators feel. You can see that on any other Web communities. It works like that and this is how they can recruit their "Community managers", "Moderators", or any other terminology like that, except the true one which is "Censor" ! I can feel a bit sorry for them, but not yet cry or feeling compassion for them ! The world is too much full of "moderators" ! At one certain time in Europe (39-45) they were called "zealous informers"... but the noise of the boots disappeared and the name with it. Nowadays, this name is more trendy, and no longer shameful
Of course it's easy to understand that, if their job were to help the users, and if they had a mean to help those who have the problem of "Professional use", they just will do it !... So, it's obvious that's not their job... then, what would be their job ?... Let's anyone who is not too much "moderator" in one's brain to conclude !
2
Same here. My parents are in their 80s. they've been hacked, twice. I use it to help them and move to multiple machines I have a my home. I was shut down in July for suspected commercial use. After investigation I was told that if I access one of my PCs from starbuck you get flagged. I remembered helping my dad from starbucks while on the road just before the flagging and timeouts occurred.
I went through the ticket process and was certified non-commercial and restored on August 11th. I got an email from teamviewer announcing the restoration.
I was good for a couple months. Now i'm seeing the "commercial use suspected" screen pops again. I tried to proactively address this again but TV has shut down their support email address. The reply I got sent me to their website to open a ticket but you have to have a license before you can create one.
They don't have a reasonable license for this type of use. Looks like they are squeezing us off of their product.
2 -
No. I tried to connect later but after 3 minutes I disconnected. Maximum 5 minutes. Then I get a message that tells me to wait a few minutes to be able to re-use ....
1
Hello
As already said, it starts again!I have always used TV for non-commercial purposes and in my contacts there are some who are visually impaired.
Why not offer a cheap license[edited by a moderator in accordance with our community guidelines]. For a retiree it's a lot but my only desire is to help.
Otherwise it will be necessary to pass to the competition.Thanks
2 -
My exact same experience with L.M.I. back when they ended offering their free remote access service. I repeatedly suggested they reduce the fees charged to personal users but they never did that. They lost me to T.V. and now it seems like T.V. is repeating their mistake. Please reduce the license fee to simple personal or hobby use clients like us and we will be happy to support your business. Having unrealistically high commercial license fees for us doesn't win you our business or loyalty. C'mon T.V., please learn from L.M.I.'s failures!1
I agree with the idea of a modest free replacing the free version even though I enjoyed using TV to help friends resolve problems. It’s a great help when I can’t get to machines far away.0
In July I got my teamviewer set to free (ticket 419004), but after the latest upgrade I am again getting the message of suspected commercial use. WIll I have to go through the same procedure again of proving a non-commercial use?
how to solving this problem?
I started getting these warnings myself yesterday, or the day before.
I DO connect to a corporate computer now and then, and from a corporate environment and to my home computers quite often. However, I am not in a postion where i bring my work home, and all the connections are private matters.
How do I clear the suspicion?
I have same problem. Used it over 2 years and now I suddenly marked as commercial activity user. Would like to know how this can be solved.
Ever since the recent TW update, my sessions keep timing out. A few months ago TW did the same thing. I contacted support and they fixed it. Why are they doing it AGAI?!? They now that I volunteer with a charety and maintain their computers and he seniors (computers) belonging to it. They cut me off in mid session, leaving a computer literaly unuseable. TW staff, reset it NOW! And stop messing in peoples business. If you don't get it fixed in the next 12hrs., I will crack your software you'll never interfere again. I am a retired IT tech and I will make it work without your help. You chose the wrong guy to mess with.
I have the same issue on my own email adres and on my wifes email adress.
I never used teamviewer for commercial use, never get paid for giving fammiily friend help.
Now I want to follow the solutions and send a ticket but then it seems it 's not anymore possible for private uses to make a ticket... hmm.
Help or do I need to make a new thread?
3 -
There is like 50 alternatives to TeamViewer.
Just use somthing else.
2 -
@Gaaawd wrote:There is like 50 alternatives to TeamViewer.
Hi Gaawd
Thanks for the "solution" !... But would we be so many free users who didn't think of and try your "solution" ? Maybe are you the one who didn't try anyone of those ?
I tried about 8-10 "alternatives" (the free use ones)... none works as easily, as fast and simply... as TeamViewer. None of those has all its complete functions (such as "drag & drop", or "copy & paste" files to transfer) !... In addition, some are quite complicated to make it installed and configured by your distant friends !...
Otherwise, nobody would still complain here, nor wasting time on this forum to emphasis non stop that we have been trapped.
André
2 -
Fill out the form here >> https://www.teamviewer.com/en/support/commercial-use-suspected/
2 -
@woodyboy wrote:Fill out the form here >> https://www.teamviewer.com/en/support/commercial-use-suspected/
Hi woodyboy,
Maybe should you apply for a moderator job on TeamViewer community ?...
Your "solution" is just the one they advise us ! But it doesn't work !... When you fill out this form and join your log file, you'll receive a ticket then... you'll have to wait for 1 month before you'll get reset (with none returned information about it's done or not). Then, after 1 month, if you try it from time to time, you'll finally see that it works again... but for only a few days ! And you'll get blocked again after 2 or 3 sessions' use.
Sorry, but this "official solution" doesn't really work.
André
(* I forgot so say this "solution" doesn't really work, even though you use TeamViewer in the strict "Personal use" conditions, according exactly to TeamViewer terms of policy... of course)
Sorry it did not work for you. It worked for me in July when I got official written notice my free use had been re-instated. I lack the time and motivation to be a moderator.
Hi woodyboy,
André
@woodyboy wrote:Sorry it did not work for you. It worked for me in July when I got official written notice my free use had been re-instated. I lack the time and motivation to be a moderator.
(About "moderator job", I was just kidding, of course :manhappy:)
Thanks for your quick reply and information. And glad to know that it worked for you. It shows at least that it could be a hope for others...
It didn't work, not only for me, but 2 of my friends, using it in the same conditions, have been in exactly the same situation as mine.
So, I would like to know how long time did you apply thta form before beeing reset on July ? And how many sessions have you remote control since July ? (I mean if it's about 3 or 30 ... or more ?)
I also don't understand why we never got any return from TeamViewer to inform us that we had been reset ?... And why we have been blocked again after 2 or 3 sessions ?... Of course, I don't think you can explain this, but I would like to get a clear explanation from a TeamViewer employee (even a moderator) at least....
André
André
(Was not sure if you were kidding about being a moderator sooooo I wanted to cover that with a no way, Jose.!)
Best of my memory, I waited almost 30 days before Team Viewer replied with the news that I was approved as a free user.. I have helped family and friends about 10 times in the previous 90 days. Short sessions and always free. Woody
@woodyboy wrote:(Was not sure if you were kidding about being a moderator sooooo I wanted to cover that with a no way, Jose.!)
Hi woody
Thanks a lot for your clear response ! Great information ! (But 30 days, same for me, is quite a long time when somebody expect and relies on your help).
Wishing it will last long for you...
So, maybe there is a way... cross fingers !
André
I also received the same message "TeamViewer ID has been reset to “free”" but i still can't connect to my Laptop via my cell phone. Sometime i am out on the road and needs some info from my laptop but even though message says "TeamViewer ID has been reset to “free”" but i still can't connect to my laptop via my cell phone and disconnected with in 2 minutes or less
