Unable to establish connection reason unknown
    JeanK Posts: 6,222 Community Manager 🌍
    Hello @Tatti
    Could you please tell us the operating systems you are using and their exact versions, and also the exact versions of TeamViewer that are installed on your devices?
  • brhuge
    brhuge Posts: 9
    @JeanK
    Main: Mac OS Sierra 10.12.6 Team Viewer Version 14.3.4730
    Remote: Windows 10 Team Viewer Version 14.3.4730
    I've tried the Remote on Numerous Different Versions of Windows inlucding WIndows 7, and  8 as well as all versions of windows 10. None of them work and all give the same error. The weird thing is if I choose Remote Control using windows authentication and enter the Windows user name and password I am able to connect just fine.
    Hello @brhuge,
    I replied to your post here: Mac to PC Remote Computer "Unable To Connect Reason Unknown" Partner Still using an older version of TeamViewer
