Hi. We bought Premium licence to upgrade our Teamviewer 9 commercial licenced installations. I created a startup script in GPO that uninstalls Teamviewer 9 and then installs TeamViewer_Full.msi, that was downloaded from Teamviewer console.
I am installing it with /qn IMPORTREGFILE=1 switch to deploy also settings which are saved in reg file.  (installed TeamViewer_Full.msi on my pc, cinfigured it and exported reg file)
The problem is as follow. If I install the msi file by double clicking on it,  in About, i got licence info : PaidLicence and Expires date, as well as channel use. But when I install it with /qn IMPORTREGFILE=1, in About, there is no info about licence, just empty. Should i bother about that, as it works as expected - doesnt say anything about missing licence?
Also I dont quite understand how to use Premium licence, we are multiple admins that will need to connect to client pcs. Do every admin need to have account in management console, and then needs to login to the TW? Or it can be usable without need to login?
Also - when installed with IMPORTREGFILE=1, I cannot log in to the TW, as the email address field is inactive. Is this normal behaivior?
Thank You!
