Chromebook as Client
My account is [the personal information has been removed as per the community guidelines. ]
I have navigated to [the personal information has been removed as per the community guidelines. ]  on a windows machine and successfully downloaded the Quick Support module.
On a chromebook I have installed the TeamViewer app for ChromeOS.
When I run the QuickSupport module on the Windows machine, I get a line in the service queue in the Management Console on my chromebook.
All ok so far.
But when I click on the Connect button I get something flash up and then nothing else happens.
Any help gratefully received.
  • Vatsilidis
    Vatsilidis Posts: 655 ⭐Star⭐
    Hi @edsyrett
    Could you please provide some screenshots before and after the issue;
    Also, which version of Teamviewer do you have in both machines?
    Please make sure to hide all your personal info, like ID, password.
  • edsyrett
    edsyrett Posts: 4
    This is what the client looks like.
    https://drive.google.com/open?id=1pCl85lPXZGI3Xa8yI3ei9oX86JuB6d0O
    .. and a movie of management console when I try to connect.
    https://drive.google.com/open?id=1D5diFfoPh4l76pXQ2ZYFUtLVEKqRA3EC
  • Vatsilidis
    Hi @edsyrett
    From the video, it seems that after pressing the button the app is trying to communicate but something blocks this action.
    I suppose you are running this on the Chrome browser and I suggest you do some steps on it. Except for this steps, it will be nice if you could download another browser like Mozzila, Opera, etc.
    Whell, here are the steps:
    • Disable your antivirus temporarily
    • Clear Chrome cache and cookies
    • Reset Chrome settings to default
    • Disable Chrome extensions
    • Try it in another browser
    Please let me know if one of this solved it for you
    Best regards
  • edsyrett
    edsyrett Posts: 4
    As it says in the title, I'm running the management console on a chromebook, so some of your suggestions are meaningless:
    • Disable your antivirus temporarily - there isn't any antivirus on a chromebook
    • Clear Chrome cache and cookies - I did that, made no difference.
    • Reset Chrome settings to default - I'm not too sure what you mean by this.  I haven't changed any settings in the browser so I suspect they are at default already.
    • Disable Chrome extensions - I haven't tried this one, Zoho Support works with all my extensions, so I'm not going to try this one.
    • Try it in another browser - I can't - its on a chromebook remember?
