Not getting confirmation email containing a device authorization link
Trying to login to TeamViewer using new computer. Not receiving confirmation email containing a device authorization link. Checked spam folder.
  • Fiona_G
    Fiona_G Posts: 689 Staff member 🤠
    Hi @jsc2000,
    Thanks for your message and welcome to our community.?
    We may confirm the emails have been successfully sent from our system. Could you please check inbox again including your spam/junk folder?
    If this issue continues, do not hesitate to contact us and we are more than happy to investigate it further for you.
    Fiona
    Fiona_G
  • slk4me
    slk4me Posts: 1
    Hi, I'm not getting the confirmation emails either. I had to create this other account so I can send a message to you. My other account is:  ***Please do not post your email address***
    Thank You So Much in Advance.
  • Fiona_G
    Hi @slk4me,
    Please kindly check your spam folder first.
    If you still couldn't receive the email, as an alternative to the Trusted Devices authorization process, you can enable two-factor authentication on your account instead. If you are using two-factor authentication, then the Trusted Devices authorization email won’t be required anymore when you sign in your account on a new device.
    Learn which Security codes and apps you can use for your two-factor authentication.
    You can find more information about the activation and deactivation of two-factor authentication here.
    I hope this information would be helpful.
    Fiona
    Fiona_G
  • Wednesday
    Wednesday Posts: 3 ✭✭
    Hey @Fiona_G
    I am not getting the device authorization link for my other account, I created this account in hopes of getting help with that.
    I have checked the spam/junk folder and it is not there. The email isn't getting blocked so I don't think it is on my end. And I cannot use the alternative route because when I try to login to TeamViewer website it asks me to authenticate, which I cannot do because I am not receiving the device authorization email.
    Thanks.
