I can't make any good connections with PC/Mobile to Mobile phone with the TViewer Host app installed, sometimes it's posssible but usually not, just because it't not possible to wake up the screen remotely. I can only see the black screen after connection. Only when I use the target phone (screen is on) it's possible to make a good connection and manage the device (LG X Power 2) which is without any password. I turned on all the notifications from this app (Host), a connection is done but nothing happen after this. Black screen - nothing else. I must turn on the screen physically and than use the remote controll. This Host app works good on different phones but not with this one. Maybe I should install something else? I don't know what to do next to make it work good for me.
Could you help me?
This detail doesn't help me at all, I'm not able to use TeamViewer on mobile. There is Android 8.0 (maybe 9) installed as I remember.
What is needed for this app to work good, what should I unlock or change in the system's settings?
I'm open for your questions.
Maybe I should use another similar app for remote connections.
Thanks in advance.
