I’m having a repeatable issue with QuickSupport on an Android 16 device, and I’d like to know if this is a known limitation or if there is any workaround.
So, in short:
Remote control works only while the QuickSupport app is in the foreground. When another app is in the foreground, control works for a short time and then stops, but the screen stream continues.
Thanks for the answer! This completely fixed the issue for me. Appreciate the help.
The solution is to disable the battery restrictions of the TeamViewer Universal Addon application. Below is a screenshot from one of our Samsung SMX-210 tablets running Android 16.
Best regards.
See what's new at TeamViewer
