customdesign.teamveiwer.com download issues
mobeustech
mobeustech Posts: 1
From any windows computer (Windows 7 thru Windows Server 2019) at any client site or location on any browser (IE 11, Edge, Chrome, or Firebox) when going to https://get.teamviewer.com/mobeustech it starts by waiting for https://customdesign.teamviewer.com/download/version_14x/wremfg7/TeamViewer_Host_Setup.exe which eventually times out and I just get the error saying "this site can't be reached" and "ERR_CONNECTION_TIMED_OUT".
However on a Mac or Linux machine using the direct link https://customdesign.teamviewer.com/download/version_14x/wremfg7/TeamViewer_Host_Setup.exe it will download the TeamViewer_Host_Setup.exe with out issue.
    JeanK Posts: 7,025 Community Manager 🌍
    Hello @mobeustech
    I recommend you to re-create a new customized Host and to re-name it.
    Then, check if it works again.
    You will find all the information you need in our Knowledge Base article here: Customized Host module
    Cheers,
