1141142144146147271
  • Bankfodder
    Bankfodder Posts: 23 ✭✭
    @jojker wrote:
    Let us know if setting up a new account works (since the IP address doesn't change). I'm trying an alternative I had overlooked. TV is still easier to use but we'll see.
    @AlexandarP
    @AlexandarP wrote:
    I have the same problem. Only I use my personal phone to connect to my pc for things such as personal documents and remote shut down. I use the service rarely and ever so often I assist my friends with their pc troubles. I especially needed the service today and my connection kept getting blocked.  At some point I got flagged for no clear reason and after two tries and three weeks, I still have yet to get a reply. I might as well create a new account if they dont reply soon. If you get any updates that would be helpful, im curious to know their reasoning behind all the flagging.
    Best of luck.
    -A
    Well the reason behind all the flagging is pretty clear – that it's their software and they want to make money from it and that people are abusing it. All that is fair enough.
    What is frustrating is that the whole business seems to be so disorganised and inconsistent and also they appear to have put a system in place to deal with people who are wrongly identified as commercial users – but the system is not operating very well.
    I don't think anyone can have any problem with teamviewer running their business and the way they want – but it's a shame that they can't get a proper system up and running. For instance, as I have pointed out, some of my devices are not blocked and one of my devices is blocked but only for incoming teamviewer connections. Outgoing teamviewer connections doesn't seem to cause any problems. This is quite amazing
  • Steve-in-FL
    Steve-in-FL Posts: 27 ✭✭
    @musicreporter wrote:
    Uninstalling and reinstalling with new acct will make no difference.
    Apparently TV records your PC's IP address,.....so the problem remains the same.
    So, what I have gathered so far is this: as mentioned by others, reinstalling will not change anything. Each machine is uniquely identified by TeamViewer and issued a unique TeamViewer ID. The PC’s IP address is not static over time. IP addresses are re-issued periodically by the router and a given IP address is not guaranteed to remain the same (although it often is). My suspicion is that TeamViewer uses some other unique identifier that ties to your machine and only your machine, something like the machine's MAC address, which is static over the life of the hardware..
    Bankfodder
    You are the only person to have mentioned a directional issue. What I can suggest is that you test all pairs of your IDs. If you can connect from ABC in your home to DEF outside your home, you should be able to connect in the other direction. Try the combinations and see if there is always a single ID that seems to fail. For me, the single failing ID was consistent and no matter what other IDs I used in combination, the connection failed. When I got that one unblocked, each of my IDs worked with all of the others. If we can identify a directional issue, that would truly be a new bit of information.
  • Bankfodder
    Bankfodder
    Thanks for this reply – and the suggestions.
    I just checked it again and I can confirm that I can teamviewer out to any machine using my PC but if I want to teamviewer into the PC then it is restricted.
    It is restricted from a Samsung S9 phone
    It is restricted from a Google Pixel C tablet
    strangely though I just tried installing teamviewer on a Google Slate and using my own account I was able to teamviewer into my PC.
    There is definitely a directional issue here. It's very strange. And clearly it's not consistent because using my own account on the Google Slate, I can teamviewer into the PC. On the other two devices, I get a commercial warning and about five minutes of use.
    I find myself wondering how long it will be before they block access from the Google Slate – or even worse, block access in both directions.
  • A couple of weeks ago, TeamViewer started giving me a popup stating that I am using the product commercially. I filled in the form and sent it in and received an email on 24 sept. stating:
    Dear TeamViewer User,
    Thank you for getting in touch with us. We are happy to inform you that your TeamViewer ID has been reset to “free”. After reviewing your request, we decided that your use case can be qualified as “personal”.
    I've since been trying daily to log in and I'm still getting the commercial use popup window with login restrictions and faster timeouts. Is there something additional that I need to do to get my TeamViewer back to what it was before?
    Thank you for any assistance you can provide.
  • Same thing here.  The "Commercial Use Suspected" form is BROKEN.  I wouldn't put it past the TeamViewer folks to have broken it intentionally.
  • @tjhall1000 wrote:
    honestly. while this issue has been happening.... i downloaded **Third Party Product** cuz i needed to watch my anime while not at home. cuz thats the only reason i use TV is to watch anime on my computer while im not home.
    [removed per Community Guidelines - Sales/Solicitation policy]
    im sad i never knew about chromes version
    What, you mean someone actually got the **Third Party Product** to work????   It's been BROKEN for the years I've tried to get it to work.
    All this would be so much easier if I could get all the family members to switch to Linux.  All I need to do then is SSH into their systems.
  • i dont know what you mean by broken. it was just plug and play for me, installed on browser. installed on phone. logged in on both and BAM it was good to go. no issues. havent noticed a single thing wrong with it. its response time is amazing
    if something if broken about it. then its user error and you did something wrong lol
  • Considering I've tried it on multiple machines, multiple OS'es over a period of 2 or 3 years, and these being machines at different locations (different ISPs), I can only presume it's Google's standard brokenness that permeates their products from search on downwards.
    I'd just use some VNC configuration if I were able to set up forwarding on everybody's routers (and I'd have to have some self-updating DDNS as well, so I would know what IP they were hanging out at).  Time to start looking at those possibilities again.
  • Steve-in-FL
    So, let me ask a question, because something you are saying is striking me. You say when you use "my own account" you can successfully TeamViewer into your PC. When you are not using your own account, what are you using? There may be a commercial connection of some sort to those other IDs. Or... perhaps doing a TeamViewer session between two different accounts is inspected some other way. Maybe a private TV account outbound is OK, but a non-private (for whatever reason) account inbound is not OK. Just throwing things out there for consideration. It would be an interesting test if you used your account on one of the machines that is failing going into your home PC.
    All of my experience is using my one (and only) TeamViewer account for all the instances of TeamViewer that I have installed, both on my personal machines at home and on the machines of friends and family.
  • DanLester
    DanLester Posts: 31 ✭✭
    Well, so as of a month ago, I got the dreaded "commercial use detected" message, and my account was disabled. Ptoooee.
    As of two weeks ago, I downloaded their "Declaration of Private Use" form, in which I assured them that I was ONLY going to use my TeamViewer for private use, and sent it in. Didn't hear anything. Just today, two weeks later, I decided, on a lark, to try it. All capabilities are restored. So they accepted my "Declaration of Private Use" form, restored my service, and didn't tell me. Thanks, TeamViewer! So if you send in that form, don't expect an answer.
    In the meantime, I've set up alternative applications (which they won't let me quote here), so I consider TeamViewer now to be sort of a sidelight. Yawn.
  • DanLester
    Unfortunately, the moderators of this forum do not allow anyone to call out TeamViewer alternatives. Just Google "TeamViewer alternatives" and you'll come up with a lot that are free. (Gosh, I hope I'm allowed to say that!) Most are functionally equivalent to TV in screen sharing, though TV is somewhat more capable in file sharing, and has a more robust user interface.
  • Bankfodder
    I only use one account. I use the same account for all my devices and that brings me to another puzzle. In the past, I have been blocked (each way) on some devices and not others. I've always thought that it was a bit strange that the teamviewer system which they have put in place to detect commercial use seems only to base its decision upon device serial numbers and not the user account.
    I find this very strange because it means that somebody who is using teamviewer commercially might actually escape being blocked by using on different devices.
    By the way, the couple of years ago I did open a second account to see if that was able to bypass the blocking but of course because the blocking appears to be based upon the device serial number, the device remained blocked. I have since cancelled that account.
    I don't really see any point in playing fast and loose with teamviewer. It's their software and there are entitled to run it as they wish. I'm very grateful to have some free access to it but I wish they would sort their systems out.
    They could give:
    better support
    better communication
    Better response times
    transparency
    generally, a better system which takes into account people's accounts as well as device numbers
  • @User333717
    Calm down.  I know it is frustrating, but like or not, you have to follow the rules.  Don't turn this into a war on TV.  They are a private company offering professional services for free to personal users.
  • Hallo,
    ich habe immer mal wieder Freunden/Familie/Verwandten mit TeamViewer bei Computerproblemen weitergeholfen, seit gestern sind all meine Verbindungen auf 5 minuten begrenzt mit dem hinweiß "verdacht auf kommerzielle nutzung"
    wie kann ich das wieder da
  • DanLester
    I agree. TeamViewer is offering users value as a free service. That being said, the value is minimized if users have to jump through hoops to use it. Years ago, TeamViewer used to be the definitive free app for controlling remote machines. Not so anymore.
    Sometimes that's all you need anyway.  I know for my purposes I just need to connect to a family member's machine to troubleshoot something (or to a machine in the other room I'm doing a test installation on).  I don't need to chat through the application, I don't need to conference in other people, and can in some cases use WinSCP to do file transfers to/from my home machine.  Biggest issue comes about from knowing the remote machine's address, and tunneling through without having to open more holes in a firewall/router.
  • Hello
    I have a problem with my Teamviewer account: I´m being kicked out of the system claiming to be using the program commercialy. That is not true, I´m using Teamviewer for personal use only, devices connected are:
    My laptop.
    My wife grandfather´s laptop.
    My grandfathers laptop.
    I am using Teamviewer to help our grandparents with their computer questions.
    Can you convert my account back to normal state as I am unable to provide any assistance to them while being kicked out?
  • fidmas
    fidmas Posts: 4
    I submitted the form requesting them to analyze my usage, to prove it wasn't being used commercially months ago. Never even a reply. They don't care. Use another product. I gave up.
  • I'm not using it for commercial use but I have a message requiring I pay to get the commercial version. How can I fix this. I only use it with family and friends. I've tried uninstalling and reinstalling. Or how can I find out who I connected with that has a commercial version so I know. IMG_5846.JPG
  • Bankfodder
    I'm afraid that there's nothing you can do except to contact teamviewer using their special "commercial use suspected form" and to make your case. Customer support seems to be very patchy and the approach to suspected commercial use doesn't seem to follow any particular pattern or logic that people can understand.
    If you get unblocked then it's great.
    I've never seen a message quite like that one. It's normally more cautious and says that the commercial uses suspected and doesn't talk about your team your partner. This message is new to me
  • Steve-in-FL
    @rkotkas
    Go to the very first post in this thread to find all the info you need to get this resolved. Nothing can be resolved by asking here. (Note that some people have successfully gotten the problem fixed, others have not,)
    Here is a direct link to the form:
  • fidmas
    fidmas Posts: 4
    Thanks, but that's the form I used twice months ago.  No replys.  I'm getting friends and family to use **Third Party Product** even though it's more trouble to do remote restarts.
  • @DanLester
    I agree, Dan, but I think what is going on right at this moment is a bump in the road, not a permanent problem.   It is going to take some time for TV to get all this sorted out, but I think their ultimate goal is to continue to offer this service for free for private use.  TV has tens of millions of private users and devising a system to monitor all of them for commercial use without getting a few false positives, is extremely difficult and will take a lot of refining to fine-tune.
    I went through the same thing in 2017 with Youtube's ADpocalypse. Overnight virtually ALL content was deemed as "Not AD friendly".  It took months for it to get better and really is only now starting to smooth out.
    The same thing happened when Google shut down Panoramio and deleted billions of Geolocated photos from Google Maps. It took years for them to get that mess straightened out. Speculations ran rampant about why they did it and whether or not they were lying about fixing it. I can give you a link to the 100-mile long thread I participated in on that.
    I said it once, and I will say it again.
    "You can catch more flies with honey than with poison."
  • IgorZ
    IgorZ Posts: 5
    Hello!
    Teamviewer-host v14 - not working software.
    TeamVIEWER team - test Teamviewer-host v14 with juussi raspberry pi3 !!! After a reboot, he cannot find an Internet connection, but there is a connection with the Internet for other programs!
    A terrible version of the product over the past seven years, return to v13 !!!!
    The time limit of 5 minutes is just a mockery !!! teamviewer takes 2 minutes to connect !!!
    Greed will not bring to good!
  • fidmas
    fidmas Posts: 4
    Then how about a simple automated response even? Maybe “We’re sorry for the inconvenience, and we’ll get back to you once we’ve determined you’re not a crook.” I never even got a conformation that the form was received. Nothing. Totally ignored. Not even “We won’t talk to you without money up front.”  Honey (one way) doesn’t last forever. There are other free products that are almost as good, and even better in some ways. One with initials that rhyme with “Are You”.
  • fidmas
    fidmas Posts: 4
    I would pay it, but I suspect my 5 to 10 friends and family, who need the help, wouldn't wouldn't spring for anything.
  • I’m experiencing the same problem. I’ve used TV for years, using Same computer, iPad, & iPhone to assist my brother, obviously non- commercial use. I first received the commercial use message last year, filled out the form, & my acct was reset. Now, I’m getting the same warning, so I again filled out the form (2weeks ago), even listing my brothers 3 pc’s that I assist him with. Still have no response from TV; sent email last week, but still nothing. Not sure what their issue is, so I deleted the app from iPhone & iPad - still no joy. I wondered if a vpn could cause this, but I never use von with TV. I’m Totally in dark as to what I should do, especially frustrating as my brother keeps asking me for help, & I can only log onto his pc for about 1 minute. Anyone know why TV won’t answer my form submitted 2 weeks ago (up to 7 days was supposed to be the wait period). Very frustrating. Wish I could upgrade, but I could never afford the commercial rate, just to help my brothers family.
  • Bankfodder
    Yes, it is extremely frustrating.
    One really bizarre thing is that they sell licenses to use the software at a commercial rate which is really out of reach of any ordinary individuals.
    I don't make any money out of it but I would be happy to pay a small annual subscription – but it seems that that is not possible.
    The leap from £0.0 for private non-commercial use to a basic commercial licence is enormous.
    I suppose they must have their reasons but it all seems a bit crazy to me – and many other people
  • Please a link to where exactly is your lasy post?
  • All of sudden I began getting "Commercial Use Detected" message while I was using Team Viewer. Since I haven't been using TeamViewer all that much over the past couple of months, I have a theory.
    Although I was using my personal laptop, I'm guessing that TeamViewer detected my usage of a major corporation's WiFi to make the connection and assumed that I was using a work laptop to connect to a home computer.
    Is my theory correct, any usage of a corporate WiFi for making connections will be deemed a commerical use?
    If so, I'm guessing I'm only allowed to non-business WiFi to make any remote connections. Is that right?
    I just want to understand the playing field and avoid violating any terms.
