Sunsetting the multi-window user interface
It would be the best to divide the program into two modules:
- "Main Window" section (It is only the title I mean the functionality first of all), which should only includes "Computer and contacts" and "Remote Control",
- "Add-ons" or "Professional Services" section (or however else - see point no 1) which should contains the rest of modules and all of those that will Teamviewer team will create in the future,
so that everyone could use it depending on needs (give us the possibility to personalize GUI - even allowing us to use only the new interface). There is a lot of real specialists who use teamviewer only for support despite to the fact they bought full version of software (corporate for instance - they need more channels, quick support module or ticket module ).
Of course, it's only my opinion.
8 -
Worst move you could make.. I have 2 accounts and used the rip-off section on the left side of my screen, for ease and accesability. that is no longer an option.. Makes me wonder if there is another service out there that may suit my needs better.
You removed a feature that had no detriment to the end user, this is a HUGE mistake on your part and i really hope someone realizes this and brings back a feature that this user liked
7 -
filehippo.com they maintain older versions of Teamviewer , select older versions , 14.0..1 , 14.1 versions are available. The 14.2 and 14.3 versions listed redirect you to the Teamview site
Well, I think we all know that TeamViewer doesn't care about all the posts here about the new interface. Maybe we should ALL call them and voice our opinion?
(800) 951-45730 -
Steps to Resolve 'It's Not a Bug, It's a Feature.' Interface
1. Contact TeamViewer-Support and report that the Interface is broken (because it is)
They will tell you that Its no longer supported (got to step 2)
2. Tell Support in that case you need the download link to 14.3.4730 as the Broken Interface is unusable
You need to keep following up until they send you the functional version of TeamViewer (patch 14.3.4730) (Its a broken interface you will need to treat it a Mission-critical bug that MUST be resolved)
3. Sadly once you have the correct Installer you will need to turn off the auto-updates until the 'It's Not a Bug, It's a Feature' interface gets resolved.
This can be found here:
(Also untick the "Use new user interface" and fill in the popup)
Hopefully, they fix the 'It's Not a Bug, It's a Feature.' interface soon.
4. After doing the above steps follow up weekly with there TeamViewer-support to find out how the 'It's Not a Bug, It's a Feature.' Interface repair is going.
(You have disabled auto-patching this is now a security risk so you must follow up consistently)Last but not least Good Luck, I am unsure how TeamViewer let it get to this point, but I believe it will be on the users to get this resolved, Spend as much time with the support team as you need to get this resolved.
TDLR
Get Version 14.3.4730 (Last Stable Version) Install it, turn off the auto-update, follow up with Support until issue resolved.2 -
Great work, @DanielB ! Keep it up. I'm not going to waste much time on TeamViewer anymore because all I've gotten for doing just that the last 4-5 years is increasingly blatant disregard, fewer avenues to submit tickets, and less and less customer-centric interfaces. As soon as we get figured out what the best option is, we're jumping ship. Best to you though!
Why?
Who wanted the new UI?
Did You even ask the customers?
Where is the reason and the public customer survey for such an unreasonable major change?
We did not get asked about this kind of major GUI change and calling it sunsetting is a slap right into the face of Your paying customer base. Shame on You!
What is so wrong about multi user windows, if You have multi remote connections and multi monitors on Your desk? It's like "**bleep** Yeah get the new SingleCore CPU. So the CPU can focus on only one task at once for You!" or "Get the new OS for 1000$. it only allows You to open one programm at once, so that You can focus on it!" Please think a little bit about the upgrades, before unleashing then to the world and not just because You need an upgrade forced by the management!Teamviewer gets more and more borked with every version!
We use Teamviewer since many years (version 5), but your very wrong business decissions make it almost impossible to keep teamviewer in our company. It's like Skype. Skype was great for many years, but since Microsoft bought it in 2011 it has been rendered meaningless and unusable for many customers.
This applies to Teamviewer, too. Despite the fact, that it was only a **Third Party Product** client with and private hosted gateway server, it got more expensive with every version and the update interval decreased from aprox.3 years to 1 year without any real benefit for the average user.
Adding the security issue at top of that (Teamviewer hacked etc,) I think we all should consider a change of remote software. Since money seems to bee the only language teamviewer management seems to understand.
THANK YOU YERY MUCH TURNING GOOD SOFTWARE INTO TRASH.
6 -
I called support yesterday, and voiced my opinion. They said they would put me on the "List" of users who hate this new interface. I urge you to call and let them know.
They also sent me a download link to the June version 14.3.4730, which can use the old interface (just make sure you turn off the automatic update).
5 -
opened a ticket. Requested a fixed version with option to switch back to the old UI and not the
"Intuitive Desktop UI"
which is a big joke.
4 -
We personally hate the new user interface. Why you took away the ability for an end user to make a choice between what you think is best and what they personally want to use I will do not understand. Why couldn't you leave the ability to choose between the classic interface and what you think is new and sleek? some of us work for a living and need all the real estate we can get on our monitors. Your new interface takes up entirely too much room. The dockable single interface in the multiuser setting was great. Even your competition, log me in, has a thick client that the single view pain.
Bring back the ability for the end-user to make the choice between what kind of interface they want to use. Our at a minimum bring in the choice to have a dockable interface if we choose or a small foot interface. This was a horrible business decision to take away choices from your clients.
I do hope you actually pay attention to social media. You not getting good reviews over this last move
3 -
Hi there,
Thank you very much for your feedback regarding the new user interface.
We are aware that the window takes up too much space for some use cases and we will approach that subject.
Please stay tuned and we will inform you as soon as there are any news about it.Wish you all a great start into the new week and all the best,
Christian
Senior Manager, Product ManagementSenior Manager, Product Management0 -
I can't understand why you're patronizing the users. A choice whether to use the old or new user interface would still be useful.
Many users like me feel that the new interface is an absolute no-go.
I will go back to the June Teamviewer version and switch off updates. I hope you'll take note of the fact that the Replys indicate that apart from the developer, nobody thinks the new interface is good.
2 -
Funny how some people say "it's for you" and then take away our options and it's NOT for us. The new large window interface stinks. I want to see ONLY the slim contacts window. Many/most of us don't NEED any of the other windows constantly on screen. This is just another attempt to look like you are doing something "new" and "exciting" but actually making a program HARDER to fit into a user's work style. So sad.
@Esther3 -
The problem is that the developers are not actual USERS of their own product. They THINK they know what will work well, but are not forced to use their changes on adaily basis. All of our users need a small, compact window for contacts and nothing more. The new "interface" is actually a grab for more screen real estate, as though they are a bill board. It add nothing more in terms of FUNCTIO at all. It only takes up more real estate and requires MORE clicking. Why??? Because someone had to prove they are needed at the company as a programmer or they feel they may not be needed - so, program worthless changes to point at something they "did."
2 -
@Christian_PM wrote:Hi there,
Christian
Senior Manager, Product Management@Christian_PM, you'd better inform us on this thread, because most of us professional TV users certainly aren't going to have updates turned on to find out! And a lot of us are probably going to have made the switch to one of your competitors by then as well if it takes too long to undo your grave mistakes.
Exactly. We are a licensed user, and I've written Teamviewer multiple times about suggested improvements, but they don't listen. Whoever is working on the platform is definately not an end user.
So any suggestions for alternatives? We won't be renewing our licenses. Thanks.
Another user just suggested Cloudberry. Has anyone used it?
2 -
Thanks a lot for your feedback.
We value your opinion, and we appreciate active and critical users!
Please rest assured that we are reviewing all feedback and as @Christian_PM mentioned: we are already working on this topic.
We believe the best way to build a better product is in collaboration with our users. Your feedback is crucial for understanding your needs and solving the right problems. To achieve that we have our User Focus Program. In this program, you get exclusive previews and can give early feedback on ideas, concepts, and potential new features!
It would be an honor to have you in our program and we would like to invite you to apply for the program here: https://content.teamviewer.com/en/teamviewer-user-focus-program/
We are looking forward to receiving your feedback on the UI and other ideas, concepts, and potential new features soon.
Thanks and best, Esther
Community Manager0 -
MUCH agreed! This new interface is ridiculous to work around now! Takes up WAY too much screen instead of only a couple of inches long list. The option to still use the old list SHOULD have been kept for those who still prefer it
3 -
WOW And I thought I was the only one the HATED the new interface! As most have said it's WAY TO HUGE! I hate it in Linux, I hate it in Windows!
I have rolled back to 14.3 in windows so I'm not forced into giving up a 1/3 of one of my screens for nothing! In Linux at least after EVERY TIME I open TV I switch to contacts (the only thing I care about), drag it to half it's starting size. (STILL TO BIG) But near as annoying as the Windows version!
I know if I post any other remote software in here it gets removed. But I have sugestions on what you may try instead of forcing the MONSTER HUGE WASTE OF SPACE. Like a few others in here I'm also trying other software. I have had TV business use since version 10 or 11. But this new interface, can't just open to contacts, recent connections... So many things sending me over the edge.
Maybe do this:
1. Let us choose the default start? I think most using this as our job only want contacts?
2. Maybe have one HUGE windows but have the contact list on the bottom and working window on top, with tabs (someone else does this)
contact list on the right or left working window next to it, with tabs. (someone else also does that)
Right:
Left: (This being my favorite of the huge interfaces)
And like I said their are other companies that already use the interfaces I just posted. I like TeamViewer and would like to stay with TV. But this new interface needs to go!
(Of course you can add an area for your ads, special stuff... on the FREE VERSION)
Thank you.3 -
@beast-usa wrote:WOW And I thought I was the only one the HATED the new interface! As most have said it's WAY TO HUGE! I hate it in Linux, I hate it in Windows!
Maybe do this:
Right:
Thank you.Fantastic post! If TeamViewer doesn't want to listen to their users and make a small change, good luck on getting them to listen on a major change like this. I've been buying licenses from them since v10 as well and things are really spiraling downwards in the last couple years when it comes to listening to and helping their customers. If I wouldn't be so busy I'd probably already be settled on an alternative product, since I'm tired of beating my head against the TeamViewer wall.
4 -
@Christian_PM @Esther
Can we have an ETA on a fix, please?
"Please stay tuned and we will inform you as soon as there are any news about it."
It has been a month since your last update regarding the broken Interface patch.4 -
Still HATING the new HUGE waste of space interface! SO SUPER ANNOYING! But if I stay on version 14.3 (nice slim **bleep** of JUST CONTACTS) it keeps crashing.
So I'm forced to use the MONSTER WASTE OF SPACE version 14.6. So it looks like it doesn't matter what we like or makes life faster and easier on us?
Can we at least KILL WITH EXTREME PREJUDISE, DELETE, REMOVE, I NEVER WANT TO SEE IT AGAIN the STUPID "Recent Connections"? Who does that work for? I have a couple hundred computers in my contacts and it jumping all the way to the top to the "Recent Connections" is even worse then the huge waste of space on my left screen! No really it's like 33% of one of my 40 inch screens just to see contacts.
2 -
New version still HUGE, still has no way to not eat up 33% of one screen, still has the worthless "Recent Connections" with no way to disable it! I love looking at the 3.5 inches of wasted space.
Really PLEASE let up resize it to a normal size or give us the ability to split like 14.3. I don't need anything but contacts. AND PLEASE ADD AN OPTION TO DISABLE, REMOVE, DELETE RECENT CONNNECTIONS. Then the three or four people that like can still use it4 -
I just finished posting the Change Logs for TeamViewers January release (version 15.2) and wanted to take the chance of giving you a personal update on the latest Windows release.
Based on your feedback and the discussions with our members of the User Focus Program, our dev teams re-worked the TeamViewer interface and implemented a Slim Mode for the Computers & Contacts list.
Hint: To activate it, simply resize the TeamViewer window while you are within the Computers & Contacts tab.
The TeamViewer Insiders and the members of the User Focus Program have been testing the new Slim Mode during the last few weeks, and our dev team is currently collecting all feedback for further improvements.
Pro-tip for even more convenient work: Use the new right-click function on your computers or contacts to view a context menu :-)
If you like to become a member of the User Focus Program yourself to work together with our devs and other TeamViewer users on the future of TeamViewer, please apply via this link: https://ufp.teamviewer.com/join
We hope you like the new Slim Mode, and we are looking forward to receiving your feedback to make TeamViewer even better in the future.
Thanks and best,
Esther
Community Manager11 -
2 -
Hi @Esther , thank you for the update. I am glad to hear that you have been doing something to address all the complaints that you brought down upon your own heads unnecessarily. This looks to be a great fix for those users who use nothing but the contacts list. However, for my use case, I still have need of jumping to other parts of the software, and with this new version, that is still problematic for two reasons.
1. It still requires navigating to that tab, clicking on it, and THEN navigating to what I want and clicking on it. With <V14.3 I enjoyed the flexibility to position the contacts on the right edge of my 5th monitor with the chat window and the home TeamViewer panel stacked on top of each other directly to the left. This allowed for instant navigation to the area of choice without extra clicks.
2. On this new version, any time that I click on another tab, the window is automatically resized to the larger size to properly display the chats, etc. Since I prefer to have it parked at the right edge of my screen, the rest of the window is actually still invisible, so I have to drag it in, do my thing, then whenever I go back to contacts, I have to manually resize, drag it back to position, etc. So it is obviously a very poor UX for my use case. In fact, the slim mode really does more harm than good for me because of these reasons.
As I've explained too many times, I am just appalled that a great product (whichTeamViewer used to be) can get so caught up with their own ideas of "innovation" and "progress" that the company feels it no longer needs to listen to its loyal customers. All we are asking for is a switch to flip back to the old interface in this case. But more than that, what I personally wish for most would be the feeling that TeamViewer cares about their customers at least as much as they do for their own bottom line. As a business owner/ executive myself, I would be happy if you would share this with Herr Steil, or Mr. Goswami, Mr. Faldi, or whoever can do something about it before TeamViewer completely gives in to the competition.
2 -
Thanks for your feedback @Pilgrimlea ! I appreciate the time you took for writing this.
I understand all of your points and please rest assured that the right people here at TeamViewer will read and evaluate it!
Thanks again and have a great day,
Esther
Community Manager1 -
OMG THANK YOU SO MUCH!!!
I have over 200 computers in my list I like the tabbed windows in Windows but I HATED 30% of a 40 inch screen being used with half of it always blank. Now if I'm on Windows I can use my TV!
Now a tabbed version Linux and life would perfect. LOL Yes we always want more.
It is funny Windows yes the name is perfect WINDOWS everything needs another dam window but Teamviewer! In Linux file manager, browsers, text editors, email... everyhting is tabbed view but TeamViewer.LOL
Thanks again for SLIM MODE!!!But I do agree with "Pilgrimlea" 14.3 interface was the best for multi-monitor users. I used to do the same thing he does nice slim contacts on one screen, chat on another, computer on the center. But this is a step in the right direction.
3 -
Wonderful to see that you are working on this, listening to feedback.
I love slim, efficient, wokflow-optimized interfaces and I don't think I'm alone. Don't we all want things to be hidden while we dont need it and visible when we want them?
You are closing in on the clean contact list some of us love with this Slim Mode. For a simple solution, I'd say make the top and left bar optinally hideable, and voilà... a lot of customers happy. Perhaps a setting that says "Hide all bars automatically in Slim Mode" and when enabled the bars only show when ALT is pressed and released?
Other thoughts regarding "immediate access but still hidden until we want it" :
- Integrate the instant connect function into the search field. If we type an ID that is not in our contact list or recent connections, allow us to instantly connect to it.
- Integrate the "recent connections" into the search bar instead? When the search bar is selected but empty pushing down arrow on the keyboard (or clicking a small icon only visible inside the search field when it's selected but empty?) we get the recent connections. Might be worth testing to see if it's intuitive.
1
