Announcements
We are happy to announce the launch of
TeamViewer Web Monitoring!
⇒  Learn more here ⇐
Highlighted
Posted by Community Manager
Re: change from commercial trial to personal licence
Hi @AugustineN
Please have a look at this Knowledge Base article to get help.
Best, Esther
Find this helpful? Say thanks by clicking on the Thumbs Up button. Find more information here: Knowledge Base | Community Blog | How to get started
Highlighted
Posted by
Photon
Trial Expired - using a personal capacity
why??
i am using my team viewer for my private computers.
i really need my team viewer to work.
i already try to uninstall and re-install.
tried to remove the program with revo un-installer that remove also team viewer from registry,
i have tried to use with safe mode.
nothing help.
please H E L P me ASAP ! tnx
Highlighted
Re: Trial Expired - using a personal capacity
Hi liron,
please read this Knowledge Base article to get help with your trial.
Best, Esther
Highlighted
Posted by
Photon
Timeout for Free Version
I was told to post this question on here for some help.
My Team Viewer (free version) keeps timing out after 5 minutes. I've tried to correct this through the advanced options and it hasn't helped.
Is there a way for me to keep it logged on for longer?
Highlighted
Posted by
Digon
Re: Timeout for Free Version
I'm also facing this problem. Using version 12.0.75813.
It keeps timing out randomly in my case, sometimes it won't last a minute. it's frustating.
What's happening?
Highlighted
Posted by
Trigon
Check your log file and see what it is saying right before it gets disconnected.
C:\Program Files\TeamViewer\TeamViewer12_Logfile.log
I'm having this issue too but I believe it's because I'm leaving the session idle too long.
This is the log entry I get before disconnects
'CMainWindow::TrackIdleTime(): System goes idle. (IdleTime=344045)'
Highlighted
Posted by
Digon
I have that line but not right before the session ends, but i do have these "suspicious" entries:
2017/04/10 23:36:32.969  CStreamManager::ParticipantRemoved: Our own participant was removed, we must terminate our session
2017/04/10 23:36:32.970  RA: quality suggestion by capacity measurement: (350)
2017/04/10 23:36:32.970  RA: Audio quality set to 120000
2017/04/10 23:36:32.970  RA: Stopping capturing thread
2017/04/10 23:36:32.971  RA: LoopbackCapture with 4 discon events within 3967870 ms
2017/04/10 23:36:32.971  RA: RemoteAudioSender stopped
2017/04/10 23:36:32.971  RA: LoopBackCapture stopped
and so on.
I find these suspicious - "CStreamManager::ParticipantRemoved: Our own participant was removed, we must terminate our session" because in top of this problem im also getting a "blank tab" out of nowhere. See:
Highlighted
Posted by
Trigon
Search for a line that says 'Connection closed by user' in the log on the device you're connecting from.  That is right where the sessions are being disconnected for me but I'm not doing it thats for sure.
I'm also getting the CStreamManager:articipantRemoved message in my log and I'm also getting blank tabs appearing randomly as well.
This new release is just very buggy IMO
Highlighted
Posted by
Digon
Yes, i also have that "Connection closed by user" in the logfile from the device i'm connecting from.
There's something wrong with this build indeed. An update or answer from the devs would be appreciated.
Highlighted
Posted by
Digon
bump.
Highlighted
Posted by
Henagon
I thought I was having similar timeouts, turned out it's the x being clicked on the top left corner, (as seen in the screenshot you posted) even in full screen mode when it's not visible. Your blank page is probably from clicking the +. I haven't figured out how to move the menu or disable it. Dont recall it being there before the last update.
Highlighted
Posted by
Henagon
No connection to TeamViewer server
Hello guys,
I have a problem with my teamviewer.
I use the Teamviewer only in private use. However, Teamviewer shows the following problem: A connection could not be established.
The remaining license of your connection partner has expired.
Since your partner uses TeamViewer commercially, he or she (one of the connection partners) needs a license.
CCould you please help me out?
rregards,
KKanpet Khanna
Highlighted
Posted by
Photon
Commercial use detected, but it`s private use ?!
How can I get rid of this message and the loss of connection after 5 minutes?
I'm using it only for private purposes.
Highlighted
Posted by Former Staff
Former Staff
Re: Commercial use detected, but it`s private use ?!
Dear muser,
Thank you for your post!
Please have a look at this Knowledge Base Article:
https://community.teamviewer.com/t5/Knowledge-Base/Why-do-I-see-Commercial-use-suspected-Commercial-...
It will give you all the details on why you may be receiving that notification as well as a link to a web form via which you can contact our support team.
There are already many topics on this board that refer to the subject of commercial use and point to the relevant article. That is why I would also like to kindly remind you to use the search function before posting a question. Since we have many active users, it is very likely that it has already been answered and you can get your solution straight away :)
Katharina
Did my reply answer your question? Accept it as a solution to help others, Thanks!
Highlighted
Posted by
Digon
Yes, and from the logs it seems Teamviewer has their own participant. Sounds like they're accessing our computers.
"CStreamManager: ParticipantRemoved: Our own participant was removed, we must terminate our session"
Highlighted
Posted by
Trigon
STMREUSABLES, Sorry but this is not user error.  I've been using Teamviewer for years without issue up until the last update.  Sometimes it disconnects on it's own when I'm not even touching my keyboard or mouse after 30-60 mins.  And the blank page is not from hitting the +.  I know how that works I only have a single session open so I'm not accidently hitting the + when switching sessions  at the top.
Highlighted
Posted by
Digon
Using For Personal Use - But it Says my Trial Expired
I need some assistance. I may have accidentally sign up as a commerical user because I'm being told that my trial expired, but I 'm using it for  personal use. How can I fix this error, so  I'm able to use teamveiwer again.
Any help is appreciated.
Joy
Highlighted
Posted by
Digon
Joy
Highlighted
Re: Using For Personal Use - But it Says my Trial Expired
Hi Joy,
In this Knowledge Base article you will find all relevant information and a link to the form to contact the dedicated TeamViewer staff for this.
Best, Esther
Highlighted
Posted by
Digon
Hello Esther,
Thank you for this information.
Joy
Highlighted
Posted by
Trigon
I can confirm this issue is not present in the enterprise licensed version of Teamviewer v12.0.75813.  Either the free version is bugged or they added random disconnects.
Highlighted
Posted by
Digon
@STMREUSABLES  of course it's not by clicking the + button lol
You think we are that stupid?! It opens that tab by itself.
I love that there are no replys by the devs. Seems that they really don't care about free version.
Highlighted
Posted by
Henagon
Trial version expired
Hi. I need help. I have accidentally installed teamviewer for business and now it says that teamviewer is expired. I'm using teamviewer for personal puposes, just to connect on my second pc. How to reset licence back to free? Please help. Thank you.
Highlighted
Re: Trial version expired
Thank you, Esther
Highlighted
Posted by
Digon
BUMP
Highlighted
Posted by TeamViewer Staff
TeamViewer Staff
Re: No connection to TeamViewer server
Hi Kanpet,
Please have a look at this post :)
Julia
Highlighted
Posted by
Digon
Change to Personal Use
I'm getting 'Trial version *expired*' at the bottom of the TeamViewer panel following an instal on a new Win10 laptop.
I followed the instructions in the KnowledgeBase article, but when I submit the details on the page https://www.teamviewer.com/en/support/personal-use-verification/ , I get a 500 error:
500 Internal Server Error
nginx
Can you advise what I can/need to now, please? Thanks
Highlighted
TeamViewer Staff
Re: Change to Personal Use
Hi sayling,
Can you please try it again? I tried it now and it seems to work
Julia
Highlighted
Posted by
Digon
Still not working for me - trying in Chrome, let me try IE
Highlighted
Posted by
Digon
@Julia
Same thing in IE, and - bizarrely - Edge won't let me attach the log file!!
Perhaps I'm doing something wrong? What should I be entering as the Device ID?
Highlighted
Posted by
Digon
@Julia wrote:
Hi sayling,
@Julia
Just tried again, in Chrome, and all good.
Highlighted
TeamViewer Staff
Hi sayling,
Thank you for the update! I'm glad to hear that everything works again :)
Julia
Highlighted
Posted by
Henagon
Could you please change mz account to personal use only, I installed it by mistake as bussines. Thank you
Highlighted
TeamViewer Staff
RE: No connection to TeamViewer server
Hi @Kanpet
Thank you for your screenshots. I like to inform you, that we fixed this issue:
Please try again to fill out the form here
Thank you. :smileyhappy:
Reyhan
Highlighted
Former Staff
Dear joylild32,
https://community.teamviewer.com/t5/Knowledge-Base/Why-do-I-see-TeamViewer-trial-Your-trial-period-h...
There are already many topics on this board that refer to the subject of expired trial versions and point to the relevant article. That is why I would also like to kindly remind you to use the search function before posting a question. Since we have many active users, it is very likely that it has already been answered and you can get your solution straight away :)
Thank you in advance!
Katharina
Highlighted
Posted by
Henagon
Wrong installation
I have installed by mistake as commercial user instead of personal, How can I change it   Thanks
Highlighted
TeamViewer Staff
RE: Wrong installation
Hi @marijanabojovic
Thank you for your posts.
Could you please fill out the form in this topic here
Thanks in advance.
Reyhan
Highlighted
Posted by
Henagon
Hello, good afternoon,
I use Teamviewer as a tool to connect to several of my computers (I have many at home) and help out a lot of friends.
I used to get support by email but now they do not offer email support anymore.
Could you please change the status of my account?
Thank you very much.
Highlighted
Posted by
Photon
Trial expired
Even though I have selected a free license for personal use , I am still getting an error , saying that my trial expired ..
When I log into my TeamViewer account it says that my license is free , so why I am I getting this error ?
I need some help :-(
Thanks guys !
Highlighted
Former Staff
Re: Trial expired
Dear andreitwv2,
There are already many topics on this board that refer to the subject of expired trial versions and point to the relevant article. That is why I would also like to kindly remind you to use the search function before posting a question. Since we have many active users, it is very likely that it has already been answered and that you can get your solution straight away :)
Katharina
Highlighted
Posted by
Digon
Teamviewer personal help
A relative and I are helping my daughter with various things. She lives out of state.
Anyhow, he told me to get Teamviewer. It was perfect but then some "trial membership" ended. He told me it would be free forever. Apparently I didn't pay attention and clicked business instead of personal use. Now I can't get it to switch, even deleting and re-downloading and installing. Any way this can be fixed?
Highlighted
Posted by TeamViewer Star
TeamViewer Star
Re: Teamviewer personal help
Hi @MichaelFox
try to read this Knowledge Base article
Domenico Langone
MCSD: App Builder
Highlighted
Posted by
Digon
I got it and tried to submit a ticket. However it asks for a .log file and no where in the folder is there a .log file anywhere.
There is one that says it's a log file but it's a "text document".
Please bear with me. I am not very technologically advanced here.
Highlighted
TeamViewer Star
Hi MichaelFox,
to help you is what I'm doing ... right now
Try using the search box at the top of this community: you should find an article that explains exactly how and where to find the LOGs files required by TeamViewer: try searching for "log file".
You will find an article written by @Jeremy of TeamViewer's staff
Domenico Langone
MCSD: App Builder
Highlighted
Posted by
Digon
I tried again and all I got was no results. There is no file type of .log or log file.
The only thing that says log file in the name of the file is a text document
Highlighted
TeamViewer Star
Hi @MichaelFox,
Perhaps your doubt is clearer. :-)
You have followed what is indicated in the thread about retrieving the log file: from the folder that opens you will find several files. The one we are interested in has the following name (TeamViewerXX_Logfile -> XX = your TeamViewer version, eg TeamViewer12_Logfile) and Windows marks it as a Text Document. In fact, with the right mouse button, you can access the properties of the same and you will notice that the actual extension of the file is ".log"
However its content is really a flat text file...
Domenico Langone
MCSD: App Builder
Highlighted
Former Staff
Dear kramdish,
There are already many topics on this board that refer to the subject of commercial use and point to the relevant article. That is why I would also like to kindly remind you to use the search function before posting a question. Since we have many active users, it is very likely that it has already been answered and that you can get your solution straight away :)
Katharina
Highlighted
Posted by
Digon
Removing Licence for using a licence for personal use
Hi, my friend have problem with licence key because he installed Team viewer 12 as company user because he didn't know about it and he need only for personal use.
He try to
  • uninstall
  • remove keys from registry
  • delete folder from c:\program files x86\team viewer
  • clean all with ccleaner
  • restarted computer
  • new install and he can't install and use it for free (personal) licence
Is there any way to change this or to change only licence to "personal" ?
Highlighted
Posted by
Digon
Re: Removing Licence for using a licence for personal use
I made him a script to delete all files, folders and registry key and even that don't works, why ?
@echo off
echo Deleting registry keys
reg delete "HKLM\SOFTWARE\WOW6432Node\TeamViewer" /f
reg delete "HKCU\SOFTWARE\TeamViewer" /f
reg delete "HKCR\TeamViewerConfiguration" /f
reg delete "HKCR\TeamViewerSession" /f
timeout /t 5
echo Deleting Team View from program files
del /S /Q C:\Program Files (x86)\TeamViewer
rmdir /S /Q C:\Program Files (x86)\TeamViewer
timeout /t 3
echo Deleting Team view
del /S /Q C:\Users\%USERNAME%\AppData\Roaming\TeamViewer
rmdir /S /Q C:\Users\%USERNAME%\AppData\Roaming\TeamViewer
timeout /t 3
del /S /Q C:\Users\%USERNAME%\AppData\Local\TeamViewer
rmdir /S /Q C:\Users\%USERNAME%\AppData\Local\TeamViewer timeout /t 3 exit
Highlighted
TeamViewer Star
Hi @mlukac89,
try following the directions in this thread's solution. https://community.teamviewer.com/t5/TeamViewer-11/Your-trial-period-has-expired/m-p/2988/highlight/t...
Domenico Langone
MCSD: App Builder
