My "Wake-up" command no longer works. (Free version) Is it something I did?
I now have to physically turn on my desktop computer.
Version 15.42.7 also fails to wake a computer that will wake from version 15.39.6.
Version 15.42.6 also fails to wake a computer that will wake from version 15.39.6.
I apologise for infringing the Community Guidelines. The work around I suggested contained a link to a third-party product, not a direct competitor to Teamviewer as far as I can tell, but one which provides wake-on-lan functionality which can be used to temporarily replace that which is currently missing from Teamviewer. Once the target computer is awake, Teamviewer can then be used as normal to control it.
If the work-around above is not available to you then here is another. I have no association with the supplier of this free software but have found it useful to replace the wake-on-lan functionality currently missing from TeamViewer: [Removed as Community Guidelines]
Version 15.42.5 also fails to wake a computer that will wake from version 15.39.6.
I have been trying to get the latest version to work with "wake-on-lan" and have made progress. I did the following steps and it seemed to help.
I have also found that the sleep state seems to affect how a given device is displayed under "My Managed Devices". Sometimes even though a device is in standby, it shows that it is online and you can't wake it using Teamviewer. If I sleep a machine using the Windows start button, power, and sleep, it seems to work the best. Hitting the power button to sleep or using Psshutdown seems to confuse Teamviewer for some reason.
I spoke with our responsible team, confirming it's a known issue.
Our team is working on it to bring the functionality back at the earliest convenience.
I apologize for not informing you earlier - I thought it was linked to the new interface.
I'll inform you here once I've news to share.
Thank you all for your contribution, and talk soon!
/JeanK
@mikulik86, thanks a lot for clarifying. This is indeed a very valuable piece of information.
I just informed our responsible team about it and will ping you as soon as I have something to share.
I think there is a misunderstanding. We are not talking about the new interface here. We are talking about the old interface, where the Wake-On-LAN functionality is available, but not functional i.e. broken.
Thank you for your reports.
The Wake-On-LAN functionality is not available in the new interface yet. Our team is working on it to bring it back.
I'll ping you in this thread once I've news to share.
Thank you all for your patience and trust.
Version 15.41.10 also fails to wake a computer that will wake from version 15.39.6.
Version 15.41.9 also fails to wake a computer that will wake from version 15.39.6.
I have the same problem.
The Wake-On-LAN feature was functional before, but for some reason my router's public-facing IP address changed and now it doesn't work. I already reconfigured Wake-On-LAN in the settings of my PC TeamViewer client to use the new public IP of my router. I am able to still send a WOL packet to successfully awaken my PC from a different app on my phone, but the TeamViewer mobile app refuses to wake up my computer. I would test from another desktop client, but I don't have another network to connect to and don't have hairpin routing configured.
I installed version 15.41.8 and tested it. It failed to wake a target computer which will wake from version 15.39.6.
Yes, today version 15.41.8 is shown as current. I will test it.
It looks like new one is there but no info re this bug being fixed.
The current version is still 15.40.8 and there does not appear to be any response from the developers.
Is there any update on this?
It is a bug I used Feedback option to report this.
Also I managed to find a previous version 15.39.6 in this location: c:\Users\<UserName>\AppData\Local\Temp\TeamViewer\
I managed to install it over the 15.40.8 version without any issue and WOL is working again. I switched off automatic updates in Extras/Options/Advanced/
bug?
same problem for me, waking up with TV used to work, now it doesn't work anymore.
I reverted back to version 14.7.48671 which is on the TeamViewer web site. In the advanced options settings, I left the auto-updates on and TeamViewer updated to V15.2.2756. This version seems to have wake on Lan working fine. You need to uninstall V15.40.8 and install V14 on all you machines and let TeamViewer update to V15.2.2756. Then turn off the auto-update feature to prevent update to V15.40.8. Note - the V15.2.2756 won't let you log into V14 machines.
Can confirm @Mhaxx post, The android app does not allow me to wake up my machine, but the web management console works fine.
Here is a work-around. Use a Windows restore point to put your version back to 15.39.x and, in Teamviewer, tell it not to automatically update. WoL works again now.
I recently upgraded to V15.40.8 (32-bit) and wake on LAN quit working. I get a message saying "Failed to wake (computer name)" on the first try and no message if I try again. I had no problems with this feature on earlier versions. Has wake on LAN setup changed in any way?
Alright thanks guys! Then I will just wait for an update or something fixing that problem. :)
Me too. Since version 15.40.8 was installed it will not Wake On Lan other computers on the LAN. Other computers on the LAN which are still on version 15.39.x can still WoL each other.
Hello, no you are not the only one, I too have encountered problems with the latest update on, I woke up PCs via iPhone now it doesn't work anymore !!
Hello guys,
So I don't know if any of you experience problems with the new update but yesterday my teamviewer was updated on my PC and Laptop and since then I am experiencing some problems.
The last 10 months I have used Wake-on-lan without any problems to get my PC out of sleep with my laptop. Since the update it does not work anymore. Furthermore, since the update when I put my PC in sleep mode it is still visible as 'online' in my device list.
Can someone tell me if I am the only one experiencing these problems since the new update and if someone knows a fix?
Thanks in advance, kind regards Boaz
