Connection not established authentication cancelled
12346
  • Haz
    Haz Posts: 2
    Its working now.
    Thanks.
  • Perth WA back up
    OK, Thanks Esther.
    information on what the problem is and estimated time to rectify would be helpful.
    Thats like saying 'I know your flight is cancelled, register so we can tell you your flight is cancelled'
  • LarsK
    LarsK Posts: 3
    Finally online.
    Back to work :-)
  • Jazee
    Jazee Posts: 4
    Dear Esther,
    Please Share RCA with us?
  • It is back up and connections working now.
  • Esther
    Esther Posts: 3,623 Community Manager 🌍
    Thank you all for the confirmation!
    Looks like it is resolved. I am sorry that I was not able to give you an ETA earlier.
    Best, Esther
  • Esther,
    What about a reason for the outage can you give us that?
  • yanivbenarit
    yanivbenarit Posts: 8 ✭✭
    It's working again!!!
    Finally i can connect to my colleague who seats 2  meters from me !
  • edison
    edison Posts: 1
    finally service is up after 3 hours.
  • Problem solved. from Bangladesh.
  • They had to wait for someone to get in to turn the servers off and on again? I'll see if I actually get a reply to my open ticket about what caused the issue and how they will prevent it from happening in the future. This is not good enough service for paying thousands of dollars for corporate. It's working again. For now.
  • Problem solved from spain.
    Tnx
  • @narcsisuss wrote:
    Anyone know why I'm getting an error "Connection not established-authentication cancelled" when I try to connect all of a sudden? I was a little careless when I was clicking, but not sure what I did.
    Same Problem in austria, how long does it take?
  • Jazee
    Jazee Posts: 4
    Kill all Tv session from endtask and start new session.
  • Esther
    Thanks again for your patience with the connection issue earlier today.
    I got in contact with our developers to get some information about it.
    Here´s a summary:
    • The issue was caused by a database error in our master system which led to failing connection attempts
    • During the issue it was not possible to establish new TeamViewer connections or meetings
    • Running sessions were not affected
    • The account login, the login to the Management Console and the TeamViewer Chat were not affected
    • While detecting the cause took some time, they were able to resolve the issue instantly after its detection
    • Our developers took the necessary steps to prevent that this can happen again in the future
    • EDIT: Restarting the TeamViewer service could be necessary to make connections again
    I apologize once again for the trouble this has caused you and for the delay in the communication.
    Thanks and all the best,
    Esther
  • Shafi
    Shafi Posts: 3
    Thanks Esther,
    Now our helpdesk can able to get connected.
    Shafi
  • Kroger Feedback
  • Problem back again. Online but can't establish connection.
  • I seem to have same issue on new PC with Windows 10 OS 17134.345
    All other connections working fine
  • I am having the same problem.  I can send a chat, I can send presentation requests but when I try to connect to take over the computer remotely, it gives me TeamViewer connection not established authentication canceled.  But you can't get support and i can't find any information. I tried to uninstall, reinstall, change to open access, and nothing!
  • did you ever figure this out or get a ticket out on this
  • The next day, the connection got back to normal. I did not do anything.
  • Esther
    Hi @tactlesswonder
    Thanks for your post.
    This thread is mainly talking about a connection issue we were facing last Tuesday and which has been resolved. Please see my last post in this thread for more information.
    Feel free to start a new thread and ask the community for advice.
    We are not aware of any issues in the TeamViewer service.
    Thanks and best, Esther
  • I were using TeamViewer (v.6) today and could not establish an partner ID, instead it appears only a "-" in the partner ID field. After a few seconds I get this error msg (translated with Google from Norwegian to English):
    "Check your Internet connection.
    Probably you use a proxy server and must provide appropriate information in the options dialog."
    I'm not able to enter any partner ID that my friend gave me either. I have tried to remove TeamViewer from control panel + registry, then run teamviewer -> same result.
    I have also tried to reboot comp -> same result
    Checked my proxy settings in IE9 (detect automatically)
    Checked proxy settings in teamviewer -> use the same as my web browser (default)
    I used TeamViewer to help another friend a few days ago with no problems.
    Also when I first attempted to connect with teamviewer today everything seemed correct, until I entered my friends partner ID then hit connect or establish connection or whatever (the button you press to get further and enter password), but I did not get any password prompt, instead it says I could not establish a connection.
    Any tips? Tried to go on teamviewer.com but it says it only have support for customers who pay for the program.
    In advance, thanks for any tips regarding this.
    I'm working with computers daily so please do not feel that any tip is too advanced.
    Problem Solve or not please tell me in comments
  • haven't opened ticket specifically for this, but have for other things and they act like they've never heard anyone complaing about it ever and ask you to jump through hoops in solving the issue on your time, by installing special loggers that will capture your one of a kind error.   Good luck; I never resolved any of my issues; tv has been bad since tv13
  • Ester,
    No, it's not related to the outage. It's an ongoing problem for us. It sometimes takes as many 5 tries to get connected with each attempt showing Authentication Cancelled.
    Kevin Taylor, CGCIO
    Director of Information Technology
    City of Eden
    Eden, NC
  • Esther
    Hi @DarthKevin
    For all connection issues not related to the specific outage I recommend to start a new thread and ask the community for advice or -for license holders- send a ticket to our support staff for analysing the issue in depth.
Howdy, Stranger!
