1166167169171172358
  • bazbsg
    bazbsg Posts: 103 ✭✭
    No company could be this incompetent. The simple fact is they want us free users to be **bleep**ed off and find something else while they still pretend they are free for non-commercial use.
    Just look at the facts. this problem has been going on for years and there are close to 100 pages of contributions. And that doesn't count the posts that have been deleted like this one probably will be.
  • Bonzadog
    Bonzadog Posts: 27 ✭✭
    Which ever "Manager" who thought up this very sub-optimal scheme should perhaps be given another task...one much less damaging to Team Viewer.
  • Hi,
    I started a chat with TeamViewer Support regarding this error.
    If you are not aware, TeamViewer *monitors* the network that you are conducting your Remote Control sessions on.
    In my case, I was using TeamViewer on my employer's network to connect to my personal laptop for troubleshooting.
    Even though the usage was personal, the network it was conducted on was commercial - and that, apparently, is what TeamViewer is focusing on.  This is according to TeamViewer support agent, Angie.
    So, if you are receiving the "commercial use detected" error and you're initiating the session over a business network, you'll either have to apply for an exemption or conduct your session on a public network.
    A personal VPN may work to circumvent this detection, but I have not verified this.
    Hope this helps.
  • Bonzadog
    There are a lot of users that have been unjustifiably cut off. The question is how does TV know what commercial is or not? Very obviously TV does not know.
  • Alebro
    Alebro Posts: 1
    How do I apply to an exemption? I use TeamViewer to connect from my employer's network to my home network for browsing, music etc which is filtered out on the corporate network.
    Cheers,
    Alex
  • lyles43
    lyles43 Posts: 7 ✭✭
    Here is Section B.3.4 of the EULA:
    3.4.Scope of use for Free Version.
    The use of the Free Version is solely permitted for the Customer’s own, private, non-commercial purposes (e.g. free computer support for a spouse/partner). The use of the Free Version for the exercise of the Customer’s own trade or profession or the use for purposes for which the Customer directly or indirectly receives compensation (e.g. team work with colleagues, free support provided to third parties which have bought software of the Customer) does not qualify as private use. End
    It does not talk about the network, but about what is being done. It seems clear that TV is enforcing a different set of rules, or is taking the easy way out by using a simple-minded algorithm rather than an accurate determination of how TV is being used. Enforcement needs to match the EULA.
  • koryhay
    koryhay Posts: 1
    after reading through all this i dont feel so bad anymore.  i thought it was just me having this problem.  i mean i know i have a lot of devices in my house and like to help out my family with quick fixes but dag on... forcing me into commercial use without at least checking or some kind of warning to what could have trigged the conversion is down right **bleep**.  what needs to be done to have my account switched back and stay that way
  • DariaRS
    DariaRS Posts: 1
    I use my product to connect to my remote server that doesn't have a monitor.
    I don't get paid for it, so free lincene seems to be a good thing.
    Recently, he still disconnects me after a few seconds and gets blocked for 5 minutes, and so all the time.
    Earlier it worked without a problem.
    At this point, I am forced to use other solutions that work much less well, because I can't afford to buy a license for the whole year.
    Can you explain to me and give me more information.
    Best Regards
    Daria Wach
  • julaak
    julaak Posts: 1
    I have the same problem. My Android app says that "commercial use detected". Then it closes after few seconds, and I can't connect anymore. I can't use the software at all. And I'm not using Teamviewer commercially. This started some time ago.
    I have't even used Teamviewer except occasionally, and not for commercial use. Now I have to seek for alternative softwares if there's no solution.
  • Hallohej
    Hallohej Posts: 1
    Same here and its getting old fast....
  • Hello, when connected to a remote computer, it throws me out after a few seconds, as it was suspected of commercial use. I have 5 devices connected: a personal computer, a personal smartphone, 2 parent computers (I help them sometimes on some issues), and a personal computer at work. I do not use team viewer for commercial purposes, please unlock my account
  • shropshirelad
    shropshirelad Posts: 2 ✭✭
    to be truthful im getting a little fed up of teamviewer i have been using the software for years but the last year i have had several false commercial use detected. the 1st time they reset my teamviewer id but now its not working on any of my families computers. when i go to connect i get pop up to say commercial use detected then kicks me off. i have sent four tickets up to now and recieved no reply. i also rang the 0208 number to be told get off the line this is for paid users and that i have to shut up and wait. i dont feel 4 weeks is satisfactory when it says on the site 7 days. if teamviewer cant get there act together can anyone recommend other free remote assistant progarms
  • whatthe
    whatthe Posts: 1
    I've been using teamviewer free for years to help my friends, coworkers and my elderly parents.  for the last 6 months or so, I've been getting the same Commercial Use error.   Teamviewer support even looked into it and the deemed my account as free and reset it.  Now , the first time of trying to use it when my parents are having a windows update problem, I can't use it again because of some new algorithm is messing things up for us all.  I'm so perturbed right now, I'm so mad I can't take care of my mom.
  • SBreako
    SBreako Posts: 1
    I need to talk to a live representative to discuss the fact that I have never used nor have a need for commercial use but they have tagged me as a commercial user.  However, they don't respond to the requested information I sent in to show I am not a commercial user.  How do I contact someone at TV to discuss this?
  • It gets even crazier.
    I posted earlier how TeamViewer monitors and detects the network that you are using TeamViewer on.
    In my case, I was using TeamViewer on my company's network.
    I discovered that my company's TeamViewer *Enterprise* license expired on the same day I started getting "corporate use detected" warnings for my personal TeamViewer sessions.
    Once my company paid-the-bill and the Enterpise license was restored for my company's network, then *all* TeamViewer sessions, corporate and personal, were successful.
    So, if you're receiving the warning messages about corporate use, or you see your sessions suddenly turn to "Free-to-use" but expired, check with the network admin and/or the finance department of the network you are surfing from.
    Also, the email that TeamViewer sends for expiring Enterprise licenses gets flagged as spam - making it even more difficult to monitor.
    Hope this helps
  • I continue to get blocked from being able to connect to my PC from my Laptop. Teamviewer reason is I am using it for commercial use. This is not the case. I have tried to reach out to them on FaceBook and online. Nothing works.
    I use my laptop (which is slower than dirt) to connect to my PC so  I can browse the internet or update my budget. Really nothing more.
    I refuse to pay teamviewer for what should be free for personal use. Any help would be great. I have already complete a form that was suggested to my from their FB and they still block me.
    For the moment I use Chrome Remote Desktop to access my PC. At this point I should just go buy whatever I need to make my PC Wi-Fi compatable and be done with teamviewer all together.
  • DanMor
    DanMor Posts: 7
    Guys, I filled the form more than 1 month ago, and didn't get the answer from you. What is a problem here?
  • DanMor
    DanMor Posts: 7
    Guys, I filled the form of wrong commercial suspect more than 1 month ago, and didn't get the answer from you. I am using the Team Viewer only for personal purposes, but it's working only 1 minute now. What is a problem here?
  • shropshirelad
    Can I have a explanation to why I have put a ticket in once a week the past 4 weeks and had no reply. Keep getting commercial usage detected. I am unable to use software on my family pc until its reset. I rang support line to be told get of the line and wait.
  • Hello. I am a personal user. I am not a commercial user. I can't use it due to trial period error. Could you please help me?
  • neptune
    neptune Posts: 6 ✭✭
    I have sent a ticket for "commercial use detected", filled out the form and emailed it back in and still no response.  Why does this take so long to resolve, and why can't anyone take the time to respond to tickets/forms/inquiries??  This process is insanely long!
  • Bonzadog
    Yes, I think we have all gone through this long stage of getting re-accepted. What Teamviewer hope to achieve from this is difficult to ascertain, but Teamviewer is losing a lot of people. I like teamviewer but no longer have any trust in it because one does not know if one be regarded as a commercial user in future and the long, long wait to get recognized as a non-commercial user. Not one of your best ideas, Teamviewer -- I fail to see any strategy in your current course..
  • Nhyv
    Nhyv Posts: 1
    Hello there,
    I am aware I should be completing a form in order to get help with my issue. However, I do not have the available information to do fill it. To make this simpler, I will tell you my entire setup in a few lines.
    Laptop - I use a laptop to access my computer and work on coding whenever I'm not busy in college.
    School Computer - Well, pretty self-explanatory
    Desktop - What I store my coding tools and everything of the kind/What I remotely access
    I am able to log into my Desktop from the School Computer without receiving a commercial use suspected message then a connection expired. Friends logged into my Desktop to test it as well without an issue.
    However, I am not able to log into my Desktop from my Laptop. I automatically get both messages and my Teamviewer gets locked. I do not use anything other than Discord, Word, Google Chrome and sometimes a game or two on Steam on the Laptop.
    My friend logged into my Laptop without receiving any messages. Everything went well.
    Why is the commercial use message only happening whenever I use Laptop to Desktop ? How can I tell which device to provide in the form? I'm really unsure what to do.
  • LeTuanVn
    LeTuanVn Posts: 1
    My teamview was blocked. I am using teamviewer as non-commercially.
    My account is: [The personal information has been removed as per the community guidelines.]
  • neptune
    neptune Posts: 6 ✭✭
    TeamViewer, have you ever thought of the fact that it takes so long for you to resolve these issues that there is no way that the majority if not all of us could be using this commercially, or we would be losing tons of business??  Doesn't even make any sense.  If all these people were using it commercially, thier business would be in trouble since it takes close to a month to resolve this simple issue.
  • mavo82
    mavo82 Posts: 1
    Same for me. Using TV in a home environment, then getting a popup that my connection will be limited to 5 minutes (which would be kind of okay-ish), but then I get kicked after 1 minute and are unable to reconnect.
  • Elaine-remote
    Elaine-remote Posts: 1
    I am home user.....it thanks I am a businesss.....help
  • Hello.
    I have used Teamviewer since years and somehow I was recently marked as non free user.
    I used Teamviewer to help my parent, my gf or my friend with their laptops.
    After being marked I cannot help them anymore since the sessions only last couple minutes.
    Is there any way to get my free license back?
    Thanks in advance
  • Michios
    Michios Posts: 1
    I took bad version for comercial user no for free user. Please change me this licesne.
  • 2U1C1D3
    2U1C1D3 Posts: 1
    Hallo zusammen!
    Ich nutze TeamViewer unter Ubuntu 18.04 als 64bit-Version. Installiert habe ich derzeit aus dem deb-Package 15.3.1682, welches aktuell zum Download angeboten wird.
    Nach dem Verdacht der kommerziellen Nutzung habe ich um Reset der Sperre gebeten und das wurde auch durchgeführt. Seitdem kann ich über den Browser oder über mein Smartphone wieder auf alle meine IDs zugreifen. Nur die Linux-Installation auf meinem Desktop hat den Reset nicht verarbeitet. Hier wird mir nach wie vor angezeigt, dass der Verdacht auf kommerzielle Nutzung besteht.
    Die ID meines Linux-Rechners ist selbstverständlich auch mit meinem Konto verknüpft in dem sich mein Smartphone befindet und auch über das ich den Webzugriff durchgeführt habe.
    Ich habe bereits versucht den TV restlos vom System zu entfernen. Nicht nur über apt-get, sondern auch die überbleibenden Ordner welche mir find im Zusammenhang mit TV angezeigt hat.
    Kann mir jemand sagen woran das liegt? Wo hier noch Dateien versteckt sein könnten? Oder gibt es hier ein Procedere welches mir Tante google noch verschwiegen hat?
    Danke, Stefan
