Ive been blocked as im wrongly assumed im a proffesional... ive been using free license (which ive held for many years) to help set up my grandsons laptop which i bought for his birthday, trying to contact TeamViewer with a free license is almost impossible
Dave Soper
Hello, I only use my account for my home network and family member to offer help, after recently having to re-setup my dads computer. I have had to connect and disconnect a lot over the last week, but now I am blocked from accessing it due to overuse.
I cannot contact support to unfreeze it because I am a free user, does anyone have any ideas to what I can do?
His computer is windows 10 home, so I cannot use remote connect as it needs pro for that.
This is not for commercial usage. Please reset my licence
I have been using Teamviewer for personal use. Yesterday I was using Teamviewer. I clicked on one my contacts to connect to them then 3 instances of the same contact launched. I immediately got blocked from Teamviewer after that and it told me I needed to buy a license to continue using it. How do I fix this problem without buying a license? I am a personal user not corporate.
Team viewer is increasingly being blocked in many organisations (Government).
If Team viewer doesn't work there is no point to me subscribing.
I will have to look for another remote support solution that does work.
Anyone got any workarounds?
My connection has been blocked due to suspected commercial use, please help.
Hello
After years of using TeamViewer free without problem, I'm now getting a message "TeamViewer Free does not allow connections to customized TeamViewer clients with your own company logo. Please use the basic QuickSupport or the full version. This session will be terminated after 5 minutes."
I've only ever used TeamViewer to assist my now 94 year old father-in-law remotely. As requested on the TeamViewer website, I filled in the appropriate form to ask TeamViewer support to review my account. That was several weeks ago, but there's been no response. There's a warning that if you resubmit the form, it goes to the back of the queue.
Does anyone have any idea how to get a response from TeamViewer support? Or any idea how to fix this?
Thank you.
Alan
Last week, I entered into, via the preset chat options, a submission to request (again) re-activation of my longstanding free domestic usage following the "suspected commercial use" message. It said I could pause and return later - which I was obliged to do at the time. In the event, I have never been able to find the thread again. I also note that much seems to have changed in the help dialogues and indeed, I can no longer find any reference to "free" use. Is it simply the case that such "free" usage has now been discontinued?
Pete
Thanks Pete, that may well be what's going on......
Alan
I've been using TeamViewer for years now; I use it to control my disabled Father's computer.
Try it today and told it's suspecting me of using it professionally.
What can I do here?
I filled out the form to reset my ID, but can someone tell me how long this takes?
After over two months since requesting the ID reset, they finally reset it. This is my home server I use for home security and automation, clearly personal use.
The reset has come too late [removed per Community Guidelines]
Pick up your game TeamViewer, you're loosing customers.
I have spent so much time trying to reset with no luck. UK phone no help they just refer back to website. I have uninstalled and reinstalled but that does not help either.
Did not help that I made an error on the request to reset form which cannot be changed.
What now?
Shirley3322_556
Cant link to others teamvierwer user's computer.
Who can help me to solve this problem?
I'm using only one ID for personal use, but it's so cumbersome why the block keeps popping up as suspicious for commercial use. Please release it soon. my id! Submitted by email and pdf form. ID [removed per Community Guidelines]
I'm am an elderly home user who uses Teamviewer to connect to another computer in my house. Getting a message that "commercial use" detected and I'm cut off after a few minutes. How do I restore my personal use?
Yes, I'm at work connecting to my home computer from the network, but it is most definitely not for commercial use. I connect to my home computer from here so I can work on personal things that are on that computer. Why else would someone need a TeamViewer account to connect to their personal computer except for personal use? I'm absolutely using it within the guidelines of the personal license, so I'm not sure why it is blocking me suddenly. I've been accessing my home computer from this terminal for six months without a problem, but today it suddenly seems to think I'm using it for commercial use. I'm confused.... How do I contact TeamViewer so they can remove this block and I can get back to what I was using it for?
To whom it may concern,
I use Teamviewer on a personal level to connect to my home pc from work on a daily basis to check my emails, shop, watch my security cameras etc.. Today I went to connect and was quickly locked out. The message read "Unfortunately, we will have to limit your uasge of TeamViewer because the usage pattern suggests that you have been supporting others professionally" This is totally not the case. Who can I contact to get this resolved.
Bob
Why are my contacts times out and blocked with the free license as of the new upgrade 15.30.3 (64-bit)?
I use Teamviewer for accessing my media center PC from my wife's laptop and my PC which are on the same network. Occasionally I use it to connect to my mother in law's computer to help her. Recently my account has been flagged for commercial use which limit's the use severely to the point that it's unusable. The account reset form is not working so I can't fix this problem. The form will not accept any Teamviewer IDs and the signature area doesn't allow me to do anything. Any other suggestions on what I can do are appreciated.
Good morning,
I'm currently deployed with Defence and use TeamViewer to connect to my PC at home since I couldn't bring it with me.
Your software now thinks I'm a Commercial user.
I went here: https://www.teamviewer.com/en/reset-management/
Completed the form and click on the "Generate and Upload PDF" - Nothing.
I make an International call to the UK and just get referred back to the broken web site.
How do I address this so I can:
- Use the PC at home.
- Provide long range tech support ($0) for my wife when she complains that things don't work.
Happy to provide my details here or via email but I need to regain access (for more than 1 minute blocks) soon.
Frustrated.
I am NOT getting the email authentication when I TRY TO FILL OUT THE FORM. Why are emails not working for me...they did in the past????
I have been using Team Viewer in a Private role for many years; however, I am now seen to be a Commercial User.
How does one revert to being a Private Non-Commercial User?
The algorithm thinks I've been using TeamViewer on a professional basis and is requiring me to upgrade. Mostly I use TeamViewer to hop onto my home computer from work to grab a file I'm working on from home or something. Sure, I very rarely used TeamViewer to help a friend walk through something on their computer. I am, however, no professional.
How can I get my Account un-tagged and back to the Personal-Free level? Thank you for your consideration.
I have tested the form and was unable to replicate any issues.
As mentioned in this article, you will need to click the button below the field to add the TeamViewer IDs to the form.
Please also only enter one ID at a time:
In the signature area, use your mouse to draw a signature.
I tested this in Firefox as well as Chrome.
Should you encounter any further issues, please let us know
Josh P.
Senior Community Moderator
