I am having the same problem. I support my disabled sister remotely and am getting disconnected in under 2 minutes and am then locked out. My licence shows as "free" and activated. I have tried the ID reset procedure but this does not work. The procedure then invites you to complete a form and then create a pdf and upload it but this doesn't seem to activate so I don't know if the process has finished. It shows "suspected commercial use" which it most certainly is not. I am over 80 years old and have no intentions of making any commercial use of the product but do need remote access. How on earth does Teamviewer recognise commercial use? Clearly it finds false positives.
In the past month, I have been knocked off my connection after 5 minutes. I use teamviewer to connect to old desktop that I have setup in closet. What do I need to do to get this to work longer without purchasing a licensee.
Have a look at this thread - https://community.teamviewer.com/English/discussion/8284/commercial-use-connection-time-out#latest
Hi, I would like to inquire about the free TeamViewer license. Until now, I've been able to assist my family without any issues using the free license. I sporadically connect to computers to help out. However, today I noticed that the remote session time has significantly shortened. I can't even input the password before the session is abruptly ended, and I'm asked to reconnect in a minute. But when that minute passes, it prompts me to reconnect again for another minute. Is this some sort of error or a definitive end to the free TeamViewer support?
Where is the answer to the problem
team viewer commercial use dected, i have filled out the rest form how ever!! it happened again and im not able to fill it out again and i have cleared histery and cache also tried multiple browsers and this problem has been going on for a couple of months, support doesnt do anything as im not a paid member i have been using team viewer for more than 2 years!! all of my remoteing in is personal use! when im home and my laptop is at my dorm in college and orrr if im in college trying to remote in to my desktop and or my familys devices!!
https:// teamviewer.com/en/reset-management
OK, I think I have figured out what's happening. On the 'reset management' page it asks for the TeamViewer Id (or Id's). I put in my Id, and then continued down the page with the rest of the information requested. No joy, nothing happened when I clicked the 'generate PDF and submit' button. SOLUTION: just below the field where it asks for the Id, it says "click here to add Id". I assumed that this meant additional Id's. BUT, if you click here, you'll see your Id gets populated in a field just below. You can then go up and add additional Id's (in my case, several computer Id's on my home network), and after each one, clicking on "click here to Add..." adds these to the list. Once this was done and the rest of form filled out, I clicked on the 'generate PDF and submit' button, AND IT ACCEPTED IT! (and I got a notification that my request would be reviewed. So, be sure to click on the blue field just below TeamViewer Id, and it will probably work for you too! (no more hamster on the wheel stuff!!)
Hi there, I use teamviewer to access a few home computers, but nothing that I need to upgrade to a licensed version. I keep getting plagued with the pop ups that commercial use is suspected when it's not, it seems they're just trying to get me to buy a license, Which makes no sense in my situation and is insanely overpriced for what I need. I am not receiving any compensation from my home use. I don't even have the option to submit a ticket that I'm not using team viewer for commercial use anymore. If teamviewer sees this please fix this, so annoying.
Ry1 --> simply go to the www dot teamview dot com slash en slash reset-management (they won't let me post a link since I'm a newbie) and fill out the form as mentioned in my previous post. Good luck!
I'm having trouble retrieving my free version, I can't submit the form. It always shows error (2). I tried 4 browsers, different device, but the result is the same. i need help please
On https://www.teamviewer.com/en/reset-management/ page I don't see reset form, but the download button. If I click on the button, the PDF from previous filling starts download.
I tried 5 browsers, you have to login, so after that the problem is linked to my account and door is closed for me.
I am not able to fill the non existing form, so I am not able to reset my non-commercial license.
Can anybody help me, please?
I have a personnel account but it keeps telling me I need to upgrade and locking me out any idea how to fix this please
HI there, I'm stuck in the same situation for few days now. Mistakenly enough I did not list the local ID because I thought it was an issue only with the remote pc home.
Almost identical to what I'm going through. I have a PC downstairs but that's the only difference.
And yet, TV kicks me in seconds.
Also trying to help my mom who is learning the Adobe Suite, but needs assistance the professors sometimes don't give.
But wait! Apparently assisting my mom is commercial-use.
So home-inside-home is commercial use, home-to-parents-home is commercial use
At this point, WHAT THE HECK IS ACTUALLY ALLOWED?!?!?!?!?!
Suddenly today, 2 PC running Teamview Free tells me "You are using TeamViewer in a commercial setting" when I'm not. I only cnnect to maybe 6 -10 family PCs. How do I fix this? If I use the web interface instead of the application, it works fine. Just the app seems broken.
How do I fix this?
Many thinks in advance for your help.
Jim
My account was (for the 2nd time) tagged as possibly a commercial account. I ONLY provide support for my daughter, parents & sister. I submitted the reset form for my ID, which was approved. However, when I connect, I STILL get kicked off after 5 minutes and have to wait up to 5 minutes before connecting again for another 5 minutes. When I submitted my form, I only included my ID. Should I have included all ID's? If so, how can I submit them. When I try to submit a new form, it only gives me a .pdf of the original form submitted.
This is getting really frustrating. Teamviewer used to be a great solution, but now it seems to be getting much more non-user centric unless you pay for a commercial license.
Thank you .Carol.fg. for responding. My e-mail address is [removed per Community Guidelines]. Would you also need the ID's of others that I support (family members ONLY).
Thank you.
I use the free teamviewer for personal use. It keeps timing out every 5 min. How do I stop this from happening?
I just use for personal and help some friends of discord, why this happens?
I want to ask why it kicks me out after a few minutes and says timed out?
I use program for my PC and laptop and my father’s 2 laptops.
is it normal to kick me out or i have some issues
I have a free account but when i access the remote computer, it's only letting me on for less than 1 min. I'm trying to help my dad on his computer. This is the only thing teamviewer is used for. It's not worth me spending $50 a month to do this. how can i resolve the issue?
About now I am just interested in knowing if anyone has actually got straightened out. I was reset twice and still get the message
I have had the Free Team Viewer for a number of years. I hadn't used it for quite awhile until today,, March 21, 2024. I contacted my remote person and she allowed me. The program started up but only ran for a minute or two and then shut down. It blocked me for a couple of minutes. I tried again, and it did the same thing. How can I get the program to stay up and connected? I am not commercial, or shouldn't be. I am helping older people out of state with a photo program and computer issues from time to time. Please help. Thanks.
Karen Lowery
In the past, I had verified that my TV account was for personal use. I had submitted a letter affirming this.
Now, It's back to telling me that commercial activity is suspected ...etc.
How can I keep this from occurring?
I’m having the same issue, the form doesn’t work in Windows 11, Manjaro Linux, Linux Mint, MacOS Monterey, Chrome, Safari, Firefox, or Edge browsers. You fill out the information sign, click the boxes and the generate and upload PDF doesn’t do anything.
Since few days i am having issue using TeamViewer for personal use. It says that is has detected some business related use which is not correct
The same problem occurred 3 months ago with the same device, but it was resolved through the TeamViewer reset site. However, I have been requesting commercial use of the TeamViewer reset site for almost a week now, but it has not been resolved.
