TeamViewer thinks I’m using the software commercially!
Announcements
First Step Guides
  1. Are you new to TeamViewer and Home Office and need some help? Check out our FAQ here.
  2. New to the Remote Access Plan? Find our first steps FAQ here.
  3. Are you new to blizz and online meetings or classes and need some help? Check out our FAQ here.
Highlighted
Posted by
Digon
Re: Long term user today got teamviewer "suspected commercial use"
Same here, just started using Norton VPN  a couple of weeks ago. I'd already had several reCAPTCHAs trying to do a simple Google search. For those, disconnecting the VPN and reconnecting cleared up the problem, apparently getting away from a "bad" (maybe just busy) IP address.
I tried the  commercial use suspected  page to reset, but it seems to have problem with my TeamViewer ID. The message "Please enter your device id as it appears in your TeamViewer client." appears each time I try to submit. I've tried what I consider my TeamViewer ID, as lower case, first letter capitalized, all caps, email address, and Windows machine name, but nothing appears to work. The title on the field says "TeamViewer ID", so I didn't expect some of these options to work, but just gave it a shot.
Not a big deal at the moment, since I mostly use TeamViewer at home. I can just get up a walk to the other computer. It will be kind of a nuisance to find a replacement for the times I travel, but TeamViewer has a couple of annoying issues anyway. It sometimes fails to render specific windows, especially when connecting to my older Lenovo ThinkPad laptop.
Highlighted
Posted by
Electron
Re: Team Viewer Commercial Use
If anyone from teamviewer can get me that form I would be very thankfull.  Longterm user got this and I in no way am commercial, make/sell products.
I suspect me adding a PC and troubleshooting VPN slow connection caused mine as did thin in last 24-48 hour's. Or could be amount of time connected to my media pc.   I'm just hoping they can see mine are all on the same local network.
Highlighted
Posted by
Electron
Thank you for post claytone.  I am highly suspecting me using VPN's is causing it to.  If they looked at IP 3 computer's were in different IP's for me.  But in reality they were all in my house different room's.
It was just 2 until last 48 hours or so.  So wondering if the 3rd computer i just added in last day or two was what caused it.   Idk how many IP's it got when I was troubleshooting VPN speed. Would not suprise me if 25+ different IP's.
I'm just hoping they can see on same local network and hopefully put me back to regular.  As I'm in no way commercial.
Highlighted
Posted by
Photon
I am also experiencing issues with this. I've absolutely NOT used this for commercial use and now I'm unable to remote into my home computers while I'm away. Please fix this. No, I'm not going to buy your software, I'll simply use something else.
Highlighted
Posted by
Digon
The "commerical use" bug bit me today. I found the two similar but different forms below. I was finally able to submit the second one using the numeric TeamViewer id (### ### ###) in the device ID field. The first one asked for "TeamViewer ID", but didn't like the TeamViewer user ID I submitted. The second also asked for a log file, so I sent the latest one along. I'm not going to hold my breath, since the form says "answering your request may take up to 30 days".
https://www.teamviewer.com/en/support/personal-use-verification/
Highlighted
Posted by
Henagon
I also have this problem, can somebody solve this please?
Highlighted
Posted by
Digon
Yes, I'm going to look around for a new product.I really can't justify spending [the price has been removed as per the community guidelines.] when for the most part I could just get up, go upstairs, and sit down at the other computer.
I found there are actually two similar pages for arguing your case, links are below. I got the second one to work by including the numeric device id (### ### ###) in the device ID field. This form also requires submitting a TeamViewer log file, which I did.
The "commercial use suspected" form asked for a  "TeamViewer ID",  and wanted the numbers as well. This doesn't make much sense, since the numbers identify a particular computer. I now have two blocked computers, I'd like to get them unblocked at the same time.
The two forms actually have different purposes, The first one talks about the commerical use messages we've been seeing, and promises a response in 7 days. The second one talks about an expired trial period, something to do with the options selected when installing TeamViewer, and says a response may take up to 30 days.
I've now submitted both forms, so we'll see what happens.I really thought the second form was just a different version of the first, but failed to read carefully, due to frustration over trying to figure out what the first form wanted.
Highlighted
Posted by
Digon
Add me to the list of very angry people this morning. I ended up just removing Teamviewer and setting up RDP with noip for dynamic IP access. This happened before a couple of years ago, and they were swift in resolving my issue.  Now, it is completely the opposite. Not only can we not create a ticket or write to the support email, it now takes forever to respond. HUGE, HUGE contrast to their customer service before where it was almost immediate.
I hate being a second-class citizen to Teamviewer. I would not have minded paying for a personal license, but they don't offer one. It does not make sense to pay [The price has been removed as per the community guidelines.] for a business license when I only intend on using it personally.
Highlighted
Posted by Closed account
Not applicable
Me Too....
Highlighted
Posted by
Henagon
I also started having this issue as of today. I don't use the software commercially. I use it strictly on my personal computers.
Highlighted
Posted by
Henagon
Found this link. But yes its frustrating getting that message. I get that people need to pay for corporate use, but its frustrating for home users having to deal with paranoid bots assuming corporate use. Properly check before blocking I'd suggest.
Highlighted
Posted by
Digon
Just popped up today.  No idea why commecial use would be suspected.  I use it to connect to PC's and a laptop in my house.  Occasionally use it to troubleshoot my 88-year-old mother's PC.
Also having trouble with the form.  It wants to see "affected teamviewer ID."  I'm putting in the computer name in the "my computers" list, but keep getting "Please enter your device id as it appears in your TeamViewer client."
Great service when it was working.  Don't know what to do if I can't even submit the request form.
Highlighted
Posted by
Digon
@MaGiiK wrote:
I filled out the form, and after a week I was good to go to connect to my other PC again.
Do you happen to know what goes in the Affected TeamViewer ID field in the form?
Highlighted
Posted by
Trigon
Re: Kicks me off after 5 minutes
Apparently TV suspects you are using TV as a commercial account. Go to tech support or HElp on their website and search there for help on explaining your use is personal.
Ram
Highlighted
Posted by
Henagon
I have the same problem today, July 29. I have never used it for commercial use at all. I don't even use it to transfer files, just to control my personal servers remotely. I hope this is just some new bug that they quickly fix, otherwise I guess I'll just have to switch to "Third party product". Luckily, there are alternatives if TeamViewer wants to alienate its user base, but I hope that isn't the case. I understand that they're not making any money from me, but if you claim to offer free software forever under specific conditions, and then kick people off for not following the rules even when they are, it makes you look like a bad company. My 2 cents.
Highlighted
Posted by
Electron
Re: You can't open a ticket, instead look at the first post i...
What a pain, not sure what's going on... I just switch to a free product... what a shame, I have used teamviewer for years for personal use only, and now it's become a product that I feel is no longer worth all the hassle that I'm having to go through just to use it for my personal use.  I'll just use a remote desktop product to get to my windows machine, and use something other product for getting to my linux servers....  Sad to say, I could never recommend this product for commercial use...
Highlighted
Posted by
Henagon
i got booted out today but only on one of my computers. and its the one i absolutely need it on because i have no monitor hooked up to it. i think mine got triggered because i just got a brand new macbook so because i have 3 computers on the same account, plus my phone, it probably thinks im using it for commerial purposes
super annoying, please fix
Highlighted
Posted by
Hexagon
Heh, just saw this when my TV connection expired: Work flexibly from home for only [removed per Community Guidelines - Do not discuss price]. I guess this is what they were after, after all.
Highlighted
Posted by
Pentagon
Re: TeamViewer showed me a message "Connection blocked after timeout. Your license limits the maximum session durat
Oh well. Today I am getting the warning again when i connect to my that PC that I upgrade TV on yesterday.
it still doesn't cut me off even though it says it will.
I submitted the form today. Let's see how long it takes. Their message says it will take seven days.
Highlighted
Posted by
Electron
Same problem here. My account is mistakenly considered commercial. Please fix this!
Highlighted
Posted by
Henagon
Goodbye TV, Hello **Third Party Product**
Too much of a hassle to get TV to recognize me as a personal user.
I have switched to **Third Party Product**. Essentially the same thing as TV and no hassle.
Here is how:
[Removed as per Community Guidelines.]
Ending a years long relationship with TV because of this Commercial User Detected issue.
Highlighted
Posted by
Neutron
Re: Goodbye TV, Hello **Third Party Product**
I guess, I will follow
Highlighted
Posted by
Electron
Re: TeamViewer thinks I’m using the software commercially!
I have used this for years to support family and log into my own computers at my home with the same location/IP.
Today I got the commercial usage suspected / can only log in for 5 minutes at a time.
Strange, is there a change in policy?
Filled in the form and will see what happens
However it may end.
THANK YOU FOR A GREAT PRODUCT FOR ALL THOSE YEARS.
I HOPE THERE ARE MANY MORE TO COME.
Now back to reality, need to do some research on alternatives.
Highlighted
Posted by
Digon
Re: Dear TeamViewer User,
I did NOT receive an email from TV - but while I was doing maintenance on FAMILY computers (my Parents are 'not allowed' to attempt that ,, LOL )
I received a Pop-Up
I AM NOT COMMERCIAL/CORPORATEI AM NOT COMMERCIAL/CORPORATE
I used the 'Feedback' link to explain to them that I AM PRIVATE
-- Yes Please,  SnowBallOne -- keep us informed
Highlighted
Posted by
Photon
Knocked out
I have purchased Teamviewer but now after about 3-5 minutes i get locked out for 10 minutes and I get a message saying that I must upgrade. ?
Highlighted
Posted by
Digon
Interestingly - TeamViewer only seems to give me the commerical use warning when I use it from specific locations.
It's a real shame that TV can't be bothered to sort this out - it's a very useful program, but it's becoming increasingly obvious that they don't give a flying **bleep** about free users and, it would seem, don't want us using their software. Maybe there are too many of us and we're using too much of their resources - but you think they might just introduce a "home support" subscription instead of just annoying everyone like this.
Highlighted
Posted by
Henagon
Re: Commercial Use Detected
I have wrote an email with proper document which teamviewer staff needed and its more then a year and noone replied.
I am user with disabilities (wheelchair) and teamviewer helped me a lot connect to my other computers that were not my immediate reach. Teamviewer as a company doesnt care about their users.
What a shame.
PS: my email with form teamviewer needed was sent Thu, Jan 24 2018, 3:07 PM
Highlighted
Posted by
Trigon
To my friends here, the hiding of third party software names is a no-no as you can see from the email I got from TV. So a warning to all "the OVERSEER is watching us all." May you all live long and prosper.
Hi, tinkerstoys,
We really appreciate your participation in the forum. :-)
But, please stick to the User Guidelines  (https://community.teamviewer.com/t5/Community-Guidelines/User-Guidelines/m-p/8#M1) and try to discuss TeamViewer only.
If you are angry, that's ok. But please always be courteous and polite and do not start talking about third party products.
So, this is the last advice to stick to the guidelines. Otherwise, there can be temporary ban consequences.
Thank you very much, and if you have any further questions, please feel free to answer this message.
Looking forward to seeing you again participating in the forum.
Have a great day and a good start into the week.
Natascha
Highlighted
Posted by
Henagon
Re: Commercial Block
Same here, except I am the only one to use TV and I only have a few computers I connect to on rare occasions. Still I keep seeing pop-ups stating that I am using TV like a commercial user.
Highlighted
Posted by
Electron
TeamViewer definitely has an issue here. I upgraded and that's when the bug started appearing. I was not prompted for "personal" or "commercial" use during the upgrade.
Highlighted
Posted by
Proton
Commercial Use?
I've been using TeamViewer to connect from my laptop to my desktop occassionally and as of yesterday I can't connect for more than a few minutes because TeamViewer thinks I'm using it commercially.
The only other time I've used TeamViewer is to help my Grandma with her 'computer problems' because she's a few hours away from where I live and driving that far to fix a zoom in problem in Outlook is not fesible and TeamViewer has been great to help her out until lately.
Is it possible to get my account changed back to personal?  Or do I need to create a new account every so often to prevent this?
Please help.
Highlighted
Posted by
Henagon
Re: Commercial Use?
I'm having the same issue. I've never used it commercially but I have logged into my home computer to download movies and stuff while at work. I've always done this with no problem but I guess there's some kind of automatic flagging. I'd like to resolve this as it's definitely not used commercially. My company actually uses a competitor for work-related
Highlighted
Posted by
Henagon
Re: Commercial Use?
I am having this same exact issue. Just casually have TeamViewer installed to help troubleshoot my personal desktop and its flagging me as commercial license and boots me after less than a minute. How do I go back to personal use?
Highlighted
Posted by
Photon
Re: Commercial Use?
im having the same issue is only for personal use i login to my computer at home to browse sites that are block on my network at work, and im not using it for commercial use. what is happening why are they doing this i need this issue to be resolved soon.
Highlighted
Posted by
Henagon
I just got **bleep** by TV starting yesterday.  I am traveling in my RV and need to connect to my home pc's to check on the DVR and Blue Iris machines, and occationally my home pc.  Now TV appears to be trying to extort money from me by saying I am a commercial user, of which i am NOT.  Is this a bug or are they having money problems and need to start extorting money from us personal users now?
I have used this program for a few years since retiring and traveling in my RV.  Nothing has changed on any of my PCs or laptop, so why did it start yesterday after being on the road for 2.5 months while I am traveling to Alaska?
Highlighted
Posted by
Digon
It's looking for the numeric ID (### ### ###) of one of your machines.
Kind of odd, you think it would want your screen name or email, which would cover all your machines.
Just for reference, here's the form again:
Highlighted
Posted by
Electron
Yep I got the same thing today so I'm switching to **Third Party Product**. I dont need or use any other feature other than controlling my pcs so I won't need this software taking space on my SSD
Highlighted
Posted by
Digon
Re: Commercial Use?
It's pretty obvious that TV is either having problems or has decided on a new policy which kicks out many of its formerly free users. It would be nice if they let us know, one way or the other.
Just for reference, there's a form you can fill out:
On the form, where it asks for "Affected Team Viewer ID", it's looking for the numeric ID (### ### ###) of one of your machines. I'm not sure whether that means you need to submit this form for each of your machines, which seems illogical to me. Since it's illogical, you probably *do* need to submit multiple times.
I've already moved on to another solution, which really convinced me it was better overall. [remove per community guidelines - Sales/Solicitation policy] (I must admit I never verified that for TV.)
Highlighted
Posted by
Digon
Hi, tinkerstoys,
....various threats...
Natascha
Well, it is their little sandbox, I guess they can enforce their rules if they want to.
I notice that a reference to pricing got zapped in of my posts. That's fine, but the funny part is that the pricing info came directly from the TV website. Maybe the website delivers a custom price based on the presumed geolocation of the user's IP address, who knows. I have seen other posts with the same info, so I guess Natascha is having a hard time keeping up.
Just my budget, but 5x10E1 bux/lunation is a little high.
Highlighted
Posted by
Henagon
I got hit with it too. Not the first time they've locked me out for "commercial use" (despite the fact that I've only been connecting back and forth between 3 devices for nearly 7 years now)
Whatever, we had a good run TeamViewer. Too many good alternatives these days to keep getting hit with this **bleep**.
Highlighted
Posted by
Henagon
I get the same message now and I’ve never used TV except for personal use.  Can anyone recommend another product?  I would pay something but I’m not a business.
However it may end.
Highlighted
Posted by
Henagon
free use
Why does it says:
Private Use -TeamViewer empowers people to help people beyond borders and barriers. Providing a free plan for personal use is part of this vision: we believe that helping friends and family should be possible for everyone.
And now when I connect to my fathers PC, says that I use TeamViewer for non private use and every 3 min or so I'm logd out?
Andrei
Highlighted
Posted by
Digon
Re: free use
Add me to the list of disgruntled free license users. Been using the free version for a few years now and have never accessed any computer for commercial purposes. Like many here I'm retired and use it TV to help maintain my family's PC's.
Today I was flagged as suspected commercial use when accessing my own laptop on my local network.
I filled out the form and will try once to be reinstated but if that fails I'm out of here. Don't have the time to waste.
Mike
Highlighted
Posted by
Trigon
Re: free use
Their Commercial Use detection doesn't even make sense anymore.
I've quit using TeamViewer to remote to home from work, since my role changed I work 90% from home.
When I am at the office, I just often go without teamviewer.
Now, I did use it a few days ago to help a friend in Toronto. No issues.
My sister needs me to help resolve some PC software issues, on a Desktop at her place. I try to remote, and I'm blocked because it says I'm using Commercially.
This doesn't make sense! It was FINE, I use it ONE time, remoting from residential to residential lines, to help a friend. And now it's back to Commercial USE.
They're really trying to stamp out all their private users.
Highlighted
Posted by
Henagon
Re: free use
THis same thing happened to me.
Highlighted
Posted by
Henagon
I am getting this message and it is preventing me from remotely accessing my computers.  Why am I seeing this?  TeamViewer is great, but this lockout is frustrating and making me rethink my support of TeamViewer as a great tool. It won’t even let me post this ticket without errors.  What’s going on at TeamViewer, it used to be such a reliable and dependable tool.
Highlighted
Posted by
Digon
What are some alternatives?
Yes, good while it lasted.  I used it in China last year.  It poked thru' "the great firewall" so I was able to access my PC.  If they had a reasonable fee for personal use, I would gladly pay it.  Has been a really great service.
Highlighted
Posted by
Digon
Thanks!
Highlighted
Posted by
Digon
I just accessed my home computer from my cell phone and received the commercial use prompt.
Highlighted
Posted by
Digon
Only one of mine got blocked also.
